gday people im in need of some advice.....
ive got a 400kw at the wheels rb26 and am i need
of a new clutch... its got an osgiken twin plate in
it now thats starting to show some slip...... can you
adjust the clutch? or should i bite the bullet and get
a new unit for the beast?? can anyone recomend a
good clutch? should i get another os twin?
apparently the engine figures are 680hp/1080nm :wave:
Edited by rb27tt
https://www.sau.com.au/forums/topic/126480-i-need-a-new-clutch/
hmmmm. At @ $2151 if i was getting a new clutch i would definatley get one, but i already have a twin plate i can just replace plates. Ah well, i'll wait till this clutch dies before i make my desicion.
sounds like a decent deal.. are they better than the os giken ones? i want a clutch that will cope a flogging!!! :) all i gota do i sell my ca18det datsun 1200 now to get some more funds........
y buy 2nd hand when u can buuy new... a clutch is something i would never buy 2nd hand... sould have fractures or something in it and you wouldnt know till it broke up........ dose anyone know how the nismo rates up against the os giken or hks or even exedy do multi plate now are they any good?
the new nismo coppermix twin plate clutches are much more streetable than the OS Giken twins and tripples. I'm yet to witness how well the hold up on track, but they definately look to be the goods for street driving.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
