I tried to put in my intercooler today and managed to remove alot of skin from my knuckles.... and thats about it.
My 32 has the active front spoiler which is fitted to the exact place my cooler bolts onto. To get to the bolts on top of there mount you either have to remove the headlights or remove the front reinforment bar. Both kicked my ass :(
The nuts that hold the headlights in from are hidden behind a few hoses that can't be moved easily and I can't fit a tool in there. The front reinforcment bar is held in by 2 big bolts and 2 nuts. I got the bolt off one side easy enough but couldn't get the damned bolt off. I tried covering it in RP7 and left it a atleast an hour and still no luck.
Anyone know of a way I can get them off?
It'd be a very straighforeward install if I could remove the spoiler motors :wave:
or is there someone I can take it that'll give me a hand (and has the right tools)? I don't really wanna pay someone to do it all for me cause I want to learn to do things for myself
Cheers
-Matt
im not quite sure what ya talkign about but i had troubles getting my bumper off the intrution bar that was held by 2 plastic clips.. so in the end i just took it all off and once off the bumper was soo much easier to take off.. i didnt have to take off my lights or anything
oh sorry, intrusion bar = reinforcement bar
I wasn't exactly sure what it was called. I got the front bumper off easy enough, but the intrusion bar didn't want to come off. Theres two pieces of metal coming down where you driving lights mount to, the front spoiler and its motor's etc are mounted to the inner side of that. They have bolts that hold them on from the top of that bit of metal which is under the headlight.
If I can get the front spoiler motors off I would be set
I've taken off a few r32 bars/headlights/reos. The trick is you have to use the right tools.
when you said you can't get a tool in there, what are you trying to get in there? a spanner? some bolts can't be reached by the spanner.
also, a 1/2" ratchet and extension might be too big.
I also have a 1/4" socket set for fitting into those tight areas.
taking the bar off is a piece of cake. same as headlights. same as reo.
I've never seen that active spoiler thing, but I suppose it'll have to come off anyways for the fmic. Even if it didn't, they're pretty gay. Just rip that off if it's in the way.
Ok, let me try and explain how to do it.
Take the indicators out. It's like one screw. then just pull it.
take the wheel arch plastic off first. If you can't remove the clips easily, just break them. you can buy new ones from autobarn for like $2.
Then take the bar off. you dont' ahve to take the headlight off. There are bolts under the wheel arch plastic. and bolts where the indicator was.
the motors shouldn't be in the way, because the bolts you need to access to take off the front bar are no where near there. Secondly, you can't get off the reinforcement bar without first taking off the front bar.
ther eis no need to take off that reinforcement bar. cut it on the car. easier. but if you want to take it off, it's only 2 bolts. they're not very tight either.
Follow these instructions and you won't have any troubles. If you do it like this, the job will go from being a 10/10 like what you thtink it is now, to a 1/10.
Cheers
Edited by 97r33gtst-typeM
lol umm... I got the front bar off no problem
The reo and headlights is what I can't get off. The reo is held is by a bolt and a nut on each side. I got the bolts out and the nuts wouldn't budge so the reo wouldn't slide forward. I tried a spanner and my little socket set with no luck.
The headlights were even worse. I took the battery out and got the nut sitting under the what I think is a power stearing line. Further down is another nut but its stuck behind a solid pipe that isn't gonna move in a hurry. I could barely get a finger to it let alone a tool.
Cheers for your help
Success!
I bought a socket adapter that let me use my big wrench and got the sucker off. With a bit more swearing and skinned knuckles I finally got it on. The reo isn't sitting perfect yet and I ran out of daylight to cut the front bar but its all good sofar.
If you have a active spoiler you have a up/down button on the left of the driver. I think you have to have the hand brake on before it'll work manually for some reason. Mine was pretty loud, you could hear it over the radio if it wasn't turned up alot.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
