  • Replies 219
Ok this GB will be ending 2morrow, if anybody is interested, payment will have to be done by 2morrow.
If payments arn't done by 2morrow, then you miss out.
So this is your last chance to grab a excellent offer.
Once all payments are finalised i will put up all people paid in this group buy and rough date of all goods being dispatched.
Once again thanks to all SAU members for making this a successful GB.
hey buddy.... sorry for this late message!
im after one exh cam gear for rb25det!
im in sydney! so i can pick up!
can u pm me your bank account details and phone number!!
i can put the money in2 your account today, if i get some bank account details!
cheers Garth
FINAL LIST GROUP BUY ENDED
These were ordered today from the USA, as late payments that came through on thursday cleared friday.
I T/T the money to the USA and it takes between 2-3 days to clear, then they will despatch.
I was told it takes 7-10 shipping and handeling, so i should be starting to deliver the cam gears by roughly about the 26-27 August.
Can all of you on this list please send me your full shipping addresses, and to those who are picking up, i need your mobile numbers.
This is the list we have currently.
1) R33KID *IN PAID FOR 1 PAIR
2) 2GU UP *IN PAID FOR 1 PAIR
3) Siddr20 *KEEN PAID FOR 1 CAM GEAR
4) 180 mph *IN PAID FOR I PAIR
5)Tangles *IN PAID FOR 1 CAM GEAR
6)Kozeyekan *IN PAID FOR 1 PAIR
7)stolen *IN PAID FOR 1 PAIR.
8)Woodys *IN PAID FOR 1 CAM GEAR
9)beastien *IN PAID FOR 1 CAM GEAR
10)Munna1 *IN PAID FOR 1 CAM GEAR
11)kjb_r33 *IN PAID FOR 1 PAIR
12)bilbo117*IN PAID FOR 1 CAM GEAR.
13)johnbela*IN PAID FOR 1 CAM GEAR
14)cln *IN PAID FOR 1 PAIR
15)prelude_1976 *IN PAID FOR 1 PAIR
16)LEZZARE *IN PAID FOR 1 CAM GEAR
17)BAZR33 *IN PAID FOR 1 CAM GEAR
18)mitchy *IN PAID FOR 1 CAM GEAR
19)handyandy *IN PAID FOR 1 PAIR
20)adriano *IN PAID FOR 1 PAIR
21)stasis *IN PAID FOR 1 PAIR
22)Tragic *IN PAID FOR 1 CAM GEAR
23)mr_rbman *IN PAID FOR 1 PAIR
24)raw111 *IN PAID FOR 1 PAIR
25)jazza08 *IN PAID FOR 1 PAIR
26)luckydip *IN PAID FOR 1 PAIR
27)FoX *IN PAID FOR 1 PAIR
28)charlieR34 *IN PAID FOR 1 PAIR
29)Giffo *IN PAID FOR 1 CAM GEAR
30)Nismo Racer *IN PAID FOR 1 CAM GEAR
Total we have is 47 cam gears
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
