Hey,
Got first service since owning a r33. I dont know what oil the previous owner had in it but my mechanic (who is my dads mate) put Mobil XHP 15w-40 in it. Before having this service my oil pressure guage was mainly around the 4 mark. When cold & warm. Now since the oil change the needle is all over the joint. First thing in the morning the needle jumps right up to the bar between 4 and 8 and then after about 5 mins of driving comes down to the 4 mark, also if i drive for prolonged periods now (25 mins+) the stupid bar drops way down to the mark between 4 and 0.
Is this oil rat shiz?
Am I doing any dmg with this crap in my sump? What are regular needle readings for cold and warm?
Cheers
Mako
https://www.sau.com.au/forums/topic/126592-standard-oil-pressure/
this happened to me aswell and i am using motul 4100 full synthetic
My mate uses a MOTUL oil, i think it is called TurboCharge Light or something like that, not sure of its temp ratings but he reckons it is good shiz... but im not sure what his guage displays, i will have to ask him...
how long have you been using that oil for and has this only just started happening to you to?
When cold - oil pressure should be around 6..
When warm - @ 4,000 rpm should be around 4..
When warm - idle - should be around 2..
- Colder the oil.. the higher the oil pressure.. the harder you push the car.. the higher the oil pressure.. normal cruising - you should sit around 4 unless you come to an idle..
Oil pressure should vary.. it's normal.. if you don't know why - I suggest you read some sites on the web regarding cars or oil pressure
Edited by Links
ok kool thanx for the feedback guys, it is possible that it was doing it before i changed oils but didnt notice but im not totally sure, anyway i feel more comfortable now knowing it is normal as it does make sense i just didnt expect it to vary from 2 to 6. I will conduct more research on oil pressure and temp just for personal interest.
Thanks a lot everyone
mine does exactly this.. i think it's just below 6 at idle and when i'm doing ~2500rpm it is just above 6. but the other readings are spot on.
yeah. mine when warming up is around4-6 when warm. it idles 2-4 when on highway just below 4 but come off the highway and idle its below the 2 line. but drive again and its fine. stop and idle again and it will either be 2 or below 3. ive had it once halfway between 0-2 bar. this is on my 32GTR. im told the guage is shit and has a shitty reaction. dnt go by it and only go by the redlight on ur cluster if the light is on off goes ur engine..
Lol.... Yeah hopefully i'll never have to read that light.
Mine is all over the place aswell. It start off at about 6 for a bit then drops to 4 then after a while goes in between 0 and 2 and then goes back up to 4 and then back down to almost 0. It's really annoying because i got no idea what it's really at. looks like another guage is the way to go.
Its happened to me right after my oil change as well (motul 8100 5w40) or maybe i just didnt notice it before.
Around 6 when cold, slowly goes down to 4, then when the car gets warm goes to about 2, then after that just flutters around 2~4. This is in an R34 Gt-T btw.
  • 4 weeks later...
Guys,
I've got an R33. I've just rebuilt the engine and it drives great but I had the same problem with my oil pressure guage all over the place but it wasn't the gauge, it's the oil pressure sender under the bonnet near your oil filter.. get that changed... it only cost me 50 for the replacement part from another car... cheap fix.
in addition to the above, can anyone help me out regarding the method of changing the sender on an R33?
I have the sender and can see where the plug goes into it, just need to know how to go about changing it or whether it is best left to a mechanic. don't want oil to be spilling out all over the place if i remove it.
this is a requirement of a RWC and i kinda need this sorted this afternoon!
any help hugely appreciated.
Edited by thommo
Your oil pressure should fluctuate, it's not going to stay @ the one level constantly, as you rev the engine higher and the oil warms ujp the pressure will either build up or decrease...
As long as it doens't drop below 2 too often, and doesn't go over 7ish.. you should be fine..
If the oil pressure light comes on, your in serious trouble, so either get an aftermarket gauge, or just check to see if yours is working..
Makes sense what those have been saying about the fluctuation of the gauge. Mine does exactly that. Starting off slightly higher then dropping slightly to around 4 when warmed up and cruising and down to 2-3 when at idle. I'm using Motul Turbolight 4100 as many others are. Considering for normal suburban driving this fluctuation is normal and fine, in fact it would probably be more of a problem if this wasn't the case!
Also keep in mind other cars don't have oil pressure gauges so while oil pressure is important, especially for a turbocharged car, it isn't the be all and end all. Hell, my bf's car didn't even come with a tacho!
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
