Hi everyone i am selling my GTR as i got a raise and can now afford to get a lease. :ban: ...but also means i will have to sell my monster... :cheers:
The car has had serious money spent by myself and the previous owner. The majority of the work undertaken on the car in Japan was at the Tomei workshop and at Mercury Motorsport here in Queensland. Car has huge potential to push out more power.
The car has the following modifications;
Induction -
HKS T04S Single Turbo Conversion;
HKS stainless Steel Manifold;
HKS 48mm External Waste Gate;
HKS Air Filter;
HKS 3.5inch dump;
Custom 4 inch Titanium Intake;
Samco pipes;
100mm FMIC;
Chrome Turbo Heat shield;
Braded turbo lines (oil etc);
Engine -
Work carried out by Tomei Japan;
Tomei 262 step I cams;
Tomei Oil Pump;
Head Restrictors;
Baffled Sump;
Samco Radiator kit;
High Pressure Radiator cap;
Motal 8100 sythetic oil;
Full length carbon radiator guide
(soon to have bayside blue cam covers)
Exhaust -
External venting dump off wastegate;
Apexi Exhaust control Valve (in cabin adjustment);
HKS 3.5inch dump;
Titanium 3.5inch Cat back Exhaust;
Interior -
Momo Steering Wheel;
Pivot large shirft light;
Razo gearknob;
Greddy Electronic Oil temp gauge;
Greddy Electronic Water temp gauge;
Greddy Electronic Oil Pressure gauge;
Greddy Boost gauge;
6 point Roll Cage, bolt in;
Sound deadaning removed;
Exterior -
Shaved rear wing;
Weight reduction;
Trust front bar;
Carbon Fibre Front Bonnet
N1 Headlights
Blue/white Bulbs
Wheels/Brakes
Panasport G7 17inch mag wheels;
Race pads;
Braded lines;
Tomei master cylinder stopper;
Tomei AWD box;
Suspension -
Tein HA Pro Fully Adjustable coilovers (near new);
Replaced mounts & bushes;
Cusco 30mm Front Swayabar;
Cusco 30mm Rear Swayabar;
Cusco Front upper arms;
Cusco Front Adjustable castor rods;
Racing diffs front and rear
Other -
Flashpoint Dual Immobilizer alarm;
Power - Making 292.5 all wheel KW on 1bar of boost and 307 all wheel KW on 1.2 bar (17psi) of boost. car has been very well setup to be quick.
I am in Brisbane and after offers over $27,000 neg.
please contact me via PM, email at fsmout @ thincprojects.com or on 0404 077 220.
also check out; http://www.carsales.com.au/pls/carsales/&a...sh_id=582734956
Cheers,
Francisco
Edited by fsmout
https://www.sau.com.au/forums/topic/126723-r32-gtr-for-sale/
Sorry about the late reply...
Not sure about the fuel pump but its bigger than standard. its very loud but its in tank and i havent taken it out to check. Has got standard injectors...which i would say are highflowed for the power levels the car is producing.
The ECU is a Reytec (tomei computer) running a map flow sensor. Check out;
http://www.tomei-p.co.jp/_2003web-catalogu...dex-reytec.html
It has had the AC removed, however the climate control unit has been relocated to the center consol and is controlable etc.
Skyrine-dave, PM replied,
Cheers,
Francisco
Michael Whelans car was a silver R32 GTR, not this one.
This one is still a weapon, i've been for a ride in it and it's extremely impressive.
Good luck with the sale, for that price i'm sure you'll find someone to buy it, it's a lot of car for that kinda $$ !
Cheers,
Tommo.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
