Looks like the japs are starting to Join the GTR drag scene again. Us aussies and kiwi neighbours might have gotten them a bit cautious to the times a lot of our GTR's have layed multiple nines eights and a seven. :wave:
which aussie GTR has run a 7?
NXTTIME see the first pick buddy.:(
recently ran in england with english driver fisrt time for him using a hks air shift box first time out at santa pod went 8.2@168mph car is going to malaysia next. i have pics but will put more later.
these 2 pics
time slip in england
and launching in japan (7sec run) :D
Edited by nismo 400 R N1
NXTTIME see the first pick buddy.:wave:
these 2 pics
Thanks Nismo. I must have missed it the first time :O Nice work.
hold me to it all you like, an quad rotor or even a 20b in a full tube chassis car have struggled in the past getting into the 6 sec time zone and these are full on race cars, fiberglass everything and again TUBE CHASSIS. I stand by it till the dying day you will never see a full bodied GTR ( ie standard sus, body parts etc) with 4wd and a rb26 run a six!!!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
