After two months of waiting I finally picked up my car from the cargo mob in Freo yesterday.
and all I can say is DAMN!, its in a shitload better condition than the photo's I saw of her in Japan and came with a few extra suprises in the boot also (spare set of adjustables, stocky's, airbox, dump pipe, clear indicators). damn damn damn happy :(:D:(
now onto Stage 1 :)
Shaun
https://www.sau.com.au/forums/topic/1269-finally-got-my-car/
Adam32, full cage, recaro seats, harnesses, hks boost controller, apexi rsm, apexi turbo timer, apexi afc, sparco rims, aluminium bonnet, gtr grille, coilovers (can't remember the brand), kakimoto zaust and some other gadgets and has only done 34odd kkms. very good nick indeed.
pics
DLuded, got it in myself with the help of Geoff from PrestigeMotorsport.
Shaun
https://www.sau.com.au/forums/topic/1269-finally-got-my-car/#findComment-25380
Shaun
WOW thats a list as long as ure arm:eek:
Only 34k on the clock is excellent did u check that under the seat to see if it its legit.(not taking any of the fun outta it but its always good to check)
If you dont mind my asking what ballpark price for such a sexy beast?
https://www.sau.com.au/forums/topic/1269-finally-got-my-car/#findComment-25412
adam32: yeah 13th looks good at this point, ill ask some mates tonight and see if their interested.
boostzor: where do you check under the seat? although its a bit hard with the aftermarkets in there which jam up against the cage, its a prick sometimes just to adjust.
it set me back 17k + onroad, but its already gone 500$ over budget at the moment so itll most probably end up costing me 19k on the road.
Shaun
https://www.sau.com.au/forums/topic/1269-finally-got-my-car/#findComment-25428
Shaun
Dude you run a business right? Speedfreaks.
Claim it as a company car? whole becomes a tax deduction then :(
you'll be laughing.
PM me and i can put u in touch with someone who did this with a GTR.
https://www.sau.com.au/forums/topic/1269-finally-got-my-car/#findComment-25439
skyzzer33, on the books im officially not employed.. i did that as I was at uni and didnt want to effect my austudy and so forth. the business isnt making any money anywho as we sell most of the stuff to mates, its just a good way to get cheap stuff :O
gradenko: stage 1 = new turbo and i/c :P
gotta read damn manual for the HKS EVC and get it going properly, its supposedly set at the same levels for high/low at the moment (0.76bar) but the warning alarm still goes off sometimes (0.9bar) and its too hard to look at the gauge when this is happening to see what its actually hitting. hehe
Shaun
https://www.sau.com.au/forums/topic/1269-finally-got-my-car/#findComment-26518
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
