gday guys
looking to splash out a bit of cash on some toolage..of the automotive variety
basically after a set of those spanners that are open ended one end, and ring the other end with wratchet inside the ring
repco have set for $199. metric, with from memory, sizes 10,12,14,15,17,19
anyway, was just curious bout anyone's recommendations, or who is a good shop to buy tools from
cheers, mark
https://www.sau.com.au/forums/topic/126974-anyone-recommend-tools/
snap on make very good tools. I used to have a set, but they were stolen from my shed. grrrrrrr.
i've actually got a couple of the repco spanners. I tell you what, I cannot fault them. They are very good tools for their price. The do the same thing as my snap ons did.
The most immprotant thing I have found when looking at tools is to bring a selection of bolts of various sizes and see how tight the spanner fits onto the bolt.
Crap spanners seem to slip a lot. I was trying to install a dump into a friend's car and was using his spanners. they were shit. didn't fit onto the bolt properly.
If you like the repco ones, go have a look at supercheap auto. I personally wouldn't use any of their jacks, electrical equipment, nothing. all that stuff is a joke. it's always recalled. but funnily enough, their spanners are pretty good. not the normal ones. they're called superworks gold. they come with a lifetime warranty. you break it, you get a new one.
I have a set of the superworks gold now. very good tools. it has the needed sizes in metric and imperial. comes with ratchet and sockets too.
My particular set only has a selection of the needed sizes. $179
Honestly, get down to supercrap auto and have look. BUT DO NOT BE TEMPTED TO BUY ANYTHING ELSE. It will either blow up. poke your eye out. chop your hand off. or just not work. I bought a trolley jack, and basically, it exploded and dropped the car.
they make the best as far as many mechanics are concerned ... but do you want to pay the price of them.... theu do come with a lifetime warranty ... but you certainly do pay for it...
when i was in in the trade i bought snap on, king crome and sidchrome spanners and ratchets
Edited by akeenan
i still have most of my Snap-on tools from apprentice days and my Uncle had a Van (didnt help on price). Awsome tools but the cost Sheesh!! More better suited as a Tax dodge for business...
Anyway my mate started buying kingcrome and i am really impressed with there stuff as they seem to steal most of the good ideas from the big boys ...
Individual Tools shops are everywhere ! Ask a tradesman in your Area.
Snap on isn't the only one that supply a lifteim warranty.
Sidchrome or kingchrome - can't remember which one.
repco
superworks gold.
BTW, I can't remember which one of sidchrome or kingchrome is the good one. one of them is shit. I think kingchrome is the shit one?
I can't remember this other brand. I've got some oe their tools. They are also very good.
Edited by 97r33gtst-typeM
I would go with the kinchrome tools. Seems to be best bang for your buck in my opinion. You can get them from Bunnings etc.
Really good quality and prices are very reasonable.
Also do a google for transcript direct as thats where I got alot of stuff recently.
first up, forget snap-on. their prices have gotten a lot cheaper and so has their quality. a lot of their tools are no longer made in USA.
if you want good, check out KC or stahle wille. kingchrome is pretty average. fatz tool is no good, it's broken all the time and leaks a bit.
if there's one thing i know... it's tools and you are a fine tool.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
