gday guys
looking to splash out a bit of cash on some toolage..of the automotive variety
basically after a set of those spanners that are open ended one end, and ring the other end with wratchet inside the ring
repco have set for $199. metric, with from memory, sizes 10,12,14,15,17,19
anyway, was just curious bout anyone's recommendations, or who is a good shop to buy tools from
cheers, mark
https://www.sau.com.au/forums/topic/126974-anyone-recommend-tools/
snap on make very good tools. I used to have a set, but they were stolen from my shed. grrrrrrr.
i've actually got a couple of the repco spanners. I tell you what, I cannot fault them. They are very good tools for their price. The do the same thing as my snap ons did.
The most immprotant thing I have found when looking at tools is to bring a selection of bolts of various sizes and see how tight the spanner fits onto the bolt.
Crap spanners seem to slip a lot. I was trying to install a dump into a friend's car and was using his spanners. they were shit. didn't fit onto the bolt properly.
If you like the repco ones, go have a look at supercheap auto. I personally wouldn't use any of their jacks, electrical equipment, nothing. all that stuff is a joke. it's always recalled. but funnily enough, their spanners are pretty good. not the normal ones. they're called superworks gold. they come with a lifetime warranty. you break it, you get a new one.
I have a set of the superworks gold now. very good tools. it has the needed sizes in metric and imperial. comes with ratchet and sockets too.
My particular set only has a selection of the needed sizes. $179
Honestly, get down to supercrap auto and have look. BUT DO NOT BE TEMPTED TO BUY ANYTHING ELSE. It will either blow up. poke your eye out. chop your hand off. or just not work. I bought a trolley jack, and basically, it exploded and dropped the car.
they make the best as far as many mechanics are concerned ... but do you want to pay the price of them.... theu do come with a lifetime warranty ... but you certainly do pay for it...
when i was in in the trade i bought snap on, king crome and sidchrome spanners and ratchets
Edited by akeenan
i still have most of my Snap-on tools from apprentice days and my Uncle had a Van (didnt help on price). Awsome tools but the cost Sheesh!! More better suited as a Tax dodge for business...
Anyway my mate started buying kingcrome and i am really impressed with there stuff as they seem to steal most of the good ideas from the big boys ...
Individual Tools shops are everywhere ! Ask a tradesman in your Area.
Snap on isn't the only one that supply a lifteim warranty.
Sidchrome or kingchrome - can't remember which one.
repco
superworks gold.
BTW, I can't remember which one of sidchrome or kingchrome is the good one. one of them is shit. I think kingchrome is the shit one?
I can't remember this other brand. I've got some oe their tools. They are also very good.
Edited by 97r33gtst-typeM
I would go with the kinchrome tools. Seems to be best bang for your buck in my opinion. You can get them from Bunnings etc.
Really good quality and prices are very reasonable.
Also do a google for transcript direct as thats where I got alot of stuff recently.
first up, forget snap-on. their prices have gotten a lot cheaper and so has their quality. a lot of their tools are no longer made in USA.
if you want good, check out KC or stahle wille. kingchrome is pretty average. fatz tool is no good, it's broken all the time and leaks a bit.
if there's one thing i know... it's tools and you are a fine tool.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
