I am trying to find out the production figures for the autech stagea (RS 260)
For 1997 & 1998 - how many maufactured each year.
anyone who has any info please add to thread.
thanks
This is production details not car specification
https://www.sau.com.au/forums/topic/126991-autech-rs-260-how-many-were-made/
  • Replies 77
thanks
As far as i know Autech only madr 121 of the autechs as 260rs. And i know where is the last one 121 is!!! Its a custom made 260rs and its the only autech with sunroofs on and the engine is tined to 500hp. I suspect its tuned by Nismo called the rb26 Z2 version.
  • 3 weeks later...
MR GTR's is for sale right now, build number 121 (he claims only 121 built). i saw it on ebay 38k im sure someone wants it considering its freaking awesome, not sure if its for sale elsewhere, im sure he can talk it up better then i can.
here is the link hope it works if not, not too hard too find.
http://cgi.ebay.com.au/Nissan-Autech-Stage...1QQcmdZViewItem
isnt that a bit dodgy that it has never been complied considering that you cant have the car in the country for longer than 1 year without it being complied if it was purchased for road use.
is there any way to use nissan fast to check how many vin no's were issued for the autech models?
it needs a personal import plate but i dont know if there are time limits on personal import plates like there is on sevs
but yeah i agree definately a hot car would like to know what is so special about it other than the supposed super dooper suspension and fmic and what does the interior look like
121 sounds abit low to me, ive seen plenty of different ones at jap auction sites for the past 12 months and theres atleast 10 or so in oz so surely 90% cant be for sale or in oz already? oh and browsing SWAT japan sites there seems to be plenty of them in the club as well.
Edited by CruiseLiner
whats to say its even a genuine 260rs
and jusding by how many series 1 260's that come up at auction I dont believe that there is only 121 maybe thats how many series 2 models were made but altogether for both hmm i think not
Ok
I have edit my last post
My only advise to anyone buying "any car" of a dealer or private, for you to do your background checks and be satisfied with what you are purchasing
I would like to openly apologise to anyone for my last post :D
:D naughty Darrin :rofl:
Well all I can say is that car is pretty much what I would be looking for if I was to ever replace my stagea ( Series II Black 260rs ) and for 38k is pretty good priced...
Haha does Mr GTR want to trade for my series II RS Four S :P
I should have an answer to the quantity question very soon as I have a contact who is in japan with MR Autech himself (obviously not his real name).
You mean the owner of Autech or the desinger for 260rs?
:D naughty Darrin :(
Caught you :) Knew you werent happy with a stocker for more than a few months :(
ill give you permission to buy it if its legit :rofl:
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
