The lm's if there my old rear's they will fit on easily. If you space them out further they will hit the gaurds.
Also I will now be there. Found the short it was a wire under the carpet got clamped with the bottom seatbelt bolt. My fault. Now to put the car back together. Hoping nothing else goes wrong!
Yeh yours are for the back. 17x9.5 +38s yeh? Im expecting them to go on no prob. The fronts i have are 17x8.5 +40. I think a front offset of around +35/36 would have been better, but got sick of waiting. At the end of the day its easier to space them away form suspension arms then vice versa
  • Replies 167
No probs man, I'll pop around in the next few days mate :)
LM's hey?? details...
I have a feeling your RB crew shall spank my SR crew... until I become one of the RB crew hehe ;)
Nick: ahhh that sucks man...
Yeah tell me about it Dane. I need the practice too....Oh well, looks like I will be Ray's pit crew........Again! :)
I'll be down for a look see, do i need to put my name on any list for spectating?
Deano will be back in the s14, here's hoping for good weather and some fast times :rofl:
Sweeeeeet!!
STONNINGTON REPREZZZZZENT!! haha
He's gonna smash us...
Entry sent in :yes:
Sweeeeeet!!
Entry sent in :blink:
i wouldn't be tooooo worried.... :P , he has come from a standard s14 turbo, to the new turbz which is pretty big and the car is very very different to drive, so i would expect he is going to be getting used to it more than trying to smash people...
Oh and Dane, that day you saw the rs lib on city link, he had just come around the sweeper onto the bolty fairly swiftly then a few hundred meters down the rd lost all steering, the steering wheel was just free spinning in his hands, something to do with the rack, so so so lucky not to have caused a massive accident, the cause is yet to be determined, however to install extractors (which has recently been done) you need to muck around in the area that the rack is in along with other steering components.
so do i need to have my name on a "spectators" list?
Edited by R32gts-t
Good to see some SR power out there.
Dane, have you done anything to your car since last race?
Nah mate, nothing at all. What about you??
Greg: Yeah, I can imagine man, will take a little bit of getting used to...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
