How do u mean holding mate.
My auto r32 holds it in 1st till about 3500 sometimes. but i only assume it does this because the engine is cold or i might be putting my foot down a bit to much.
But i find it stays in 1st to long after i up change to 2nd when im giving it some. It takes to long for my gearbox to change to 2nd when im playing around.
But besides that it is regularly normal.
If u could explain how u are driving or if u are changing the gears urself.
I would like to hear what the cause is anyway.
Brenton
I know its a bit hard to explain exactly...I will take the car for a spin and try to give some more info...to me it feels like the revs get to a certain point ( not red lining but with a decent amount of right foot)..the motor holds on at a point..it should change into second but it sits at that point..for too long then changes..I did read somewhere about taking your foot off the go pedal like driving a manual (with a triptronic)..I will try this also on the test drive.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
