well last night i went to leave for work and got about 20 metres down the road and couldn't see out my rear view mirror from all the WHITE smoke so naturally i quickly pulled a u-turn and put the car in the garage and took the girlie's car to work as i was running late as it was!
Now i'd just put a new catch can on that i'd made and i just presume i didn't vent it properly (was trying to make it legal) which caused this mess!
Now this morning i put my old catch can back on which is vented with a filter and a few small 1/8 holes! I took it for a drive and it was still smoking but not quite as bad! I'm hoping this is just oil that was still in the exhaust etc burning off??? i pulled back into the garage and there was oily smoke coming from the engine bay (mainly around the turbo, can see slight oil marks/stains where the dump pipe meets the exhaust housing) and exhaust!
Basically have i stuffed something (can't see how?) or do i just need to vent my new catch can and wait for the oil to get out the system? I was reading somewhere that its illegal to have a 'venting' catch can but if you don't vent it properly does this problem i'm having happen or have i made it or hooked it up wrong?
Cheers in advance!
https://www.sau.com.au/forums/topic/127654-urgent-help-please/
Have done this a few times as well and it seems to clear up fairly quickly and I dont think it will be damaged. :(
Probably idle it off in the driveway as some mongrel will see the smoke if your on the road and dob you in to EPA.
Your breather should by rights vent back into the airbox intake.
I had the same problem, the catch can has a breather in the system... should work ok, are you still getting oil smoke? You may of damaged the oil seal on the turbo? Go have a look at your intercooler, you should find oil deposits in there! Clean it out with metho/kero (ie drain it n empty until it runs clean, DONT tip the cooler upside down as the oil will run through it lol) and clean the pipes out then go for a hard drive to burn any oil sitting in the zorst and have another look to see if that helps, personally im still abit stuck with it all but im tryin the cooler cleaning next week.
i hope its not the turbo cause i've been through that with my old turbo and my new 35/40 is only 2000kms old so it better not be that!, i'm 99% certain its the catch can because it only happened when i installed the new catch can!
The catch can needs to vent to atmo or somewhere...crankcase pressure will build up and bad breath will come out somewhere else. Std breather goes back into intake pipe so instead just put a little filter off a hose tail on your catch can somewhere and let it breath off that.
this is what i thought but i heard that venting into the atmosphere is illegal with catch cans? I have my old catch can back on (the one in the pic which vents via a filter!) It seems to be fine, just getting all the oil out the system now is the pain staking part. Mind you it is still blowing a bit of smoke but nowhere near as much!
Edited by mr_rbman
just took it for a quick hard drive and it only smokes a tiny bit driving normally but when it hits boost the smoke is much worse! To me that sounds like the turbo but considering its new and i changed the catch can and all this happened i'm still lenaing towards the catch can being the source of the problem???????????????????
just took the cooler off and there's a bit of oil in that which is probably causing the white smoke when the engine hits boost! Currently cleaning it now and will hopefully get it back on tonight fingers crossed!
Latest ZOOM has a great little article regarding crank case pressure and the ins and outs of oil catch cans and oil breather cans.
There was also a thread here recently where someone had a similar issue after putting on a new can and using wrong size hoses.
I think that thread started off saying “hi flow turbo blown” or something (because of the white smoke)
Even after fixing, there was a bit of smoke as the extra pressure had pushed oil past the turbo seals and so forth and was burning in the exhaust for a bit.
Hope that is all you have done and that nothing is broke.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
