R32 GTR/Gts-t Fujisubu 3" cat back - $350
Greddy Electrical Boost and Exhaust temp Gauges with warning lights and recall - $300 for both
HKS Step 1 Bolt In CAMS 256 9.1 IN and EXT - $700 - SOLD
R32 GTR Block, good condition - $700
R32 GTR Crank, Spun bearing on number 6 needs maching, no cracks - $300
R32 GTR Rods in Very good condition - $400
R32 GTR Pistons in perfect condition - Make a offer
R32 GTR Standard Head Gasket, brand new - $100
18x9 IMPUL RS rims with DISH, good 80% 255 tyres all round - $1600 - SOLD
Denso 550cc Injectors (Top feed) * 6 - $500 - SOLD
OS Giken twin plate clutch for R32/33 in good nick (Currently handling a 400rwhp GTR fine) - $600 - SOLD
Greddy Profec B Spec 1 (Big solenoid) - $350 - SOLD
600x300x76 Bar and Plate cooler with GTR end tanks - $250
R32 Gts-t or S13 5 bolt axle 2-way mech diff - $800 - SOLD
Nismo LM RS580 - $1900 - SOLD
R32/33 GTR Apexi Power FC with hand controller - $850 - SOLD
OS Giken twin plate clutch (T2CD) for R32/33 etc rated at 600hp in good nick $700 - SOLD
Apexi Power intake for R32 GTR (like new) - $200 - SOLD
SMS me on 0422426866
Edited by Cerbera
https://www.sau.com.au/forums/topic/128403-r3233-gtr-and-r32-gts-t-parts/
R32/33 GTR Apexi Power FC with hand controller $850
R32 GTR/Gts-t Fujisubu 3" cat back $400
R32 Gts-t or S13 5 bolt axle 2-way mech diff $800
How about pics of the OS clutch?
Plate condition
Clamp load etc
ill try and get some pics of the clutch for you. its in good condition, i was going to use it in my gtr but now i need something a lot stronger. plates are straight with heaps of meat. my mate bought it second hand from japan from a reputable dealer and it has not been in a car since it got here.
im in perth with the power fc but i can send over to you at the right price
Edited by Cerbera
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
