Hi,
I have a Y32 Cedric:
Chassis No.: PY32-770579
Model Num.: MLEARUNY32EDAE009Y
looking to find out whether the coilpack for my engine is compatible with any of the RB series engines. I believe it is the same as a CA18 coilpack... E.G. is it the same as an RB20 coilpack?
Hi,
