Could I get this VIN fasted please
Engine Number: RB25148913A
VIN: ECR33102386
I there anyway to know if your engine is the original one?
A far as i know there is no way of finding out if your engine is the original one.
Here is your fast...
hi please fast this too :google:
6u9000 ecr33135094
is it also possible to determine what the car was optioned with??
thanks in advance
Chook may be able to help you with the options as i dont know how to check that sort of stuff.
here is your fast....
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
