Guess I will jump on the band wagon for now as well...
Anybody able to assist with any info, much appreciated.
BNR32-313672
Here is your fast mate.
And a website for decoding your build plate.
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
Thanks heaps.
Just proves what I already thought.
Its a plain old GTR with a heap of NISMO stuff thrown at it. We cant have everything now can we...
Been looking for a decoding guide like that. Added to favourites now.
Edited by SSHatch
hi there,
can someone pls decipher these details as i want to know the exact year build date & associated info:
VIN: BNR32001881
MODEL: KBNR32RXFSLM2G
thanks in advance :spank:
here is your fast mate
Use this link to decode your model code
And for the last 4 letters LMZG go back to page 39 of this thread, 10 posts down i posted what they stand for.
thanks!
L - Projector Headlights (it has this)
M - climate comtrol + upgraded stereo (it has this)
(Package Extras Sign)...
Z - Black Interior Trim (it has this)
G - ABS & Viscous LSD (it has this)
interesting about the LSD as i had this looked at not long & the builder mentioned that my diff was not stock, had nitrated gears with a nismo centre, now im not sure if this was done by the previous owner OR did it come out with this from factory???
does anyone else have the letter 'G' in their model no. or is it a 1 off an added option on my gtr?
Most of the series 1 r32 gtr's (89 - sometime in 91) that i have been asked to fast have the G on the model code.
Seems like it was an option that almost everyone got at the time of new.
The later r32 gtr's (91-94) dont have the LMZG in the model code. Just seems like nissan decided to automatically put all these options onto the later models from what i have read and remove the letters from the model codes.
The nismo centre of the diff was most likely added by the previous owner.
Edited by babyskyline
    • GTR front looks good. If you don't like it, I'll swap you a rolling shell R33 for it. Give you a fresh base to start with.
    • soon I also prefer the old look. At least I have more clearance for wheels up front now.
    • @PranK I think a few links in the original post need fixing...
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
