Hey babyskyline,
Thanks mate, I promise this is the last one I ask you for :)
Its a White 1996 R33 GTR, Non V-Spec.
VIN: 6U900BCNR33023950
Engine No: RB26060767A
Hopefully this all matches up!
Cheers mate.
Edited by GTR-PWR
Hi, can someone please fast the following BCNR33040360. and also can datsuns be done aswell? if possible HGC110017540
cheers,
Here is your fast for the r33 gtr. Couldnt get the HGC110017540 to work on my version.
Hey babyskyline,
Cheers mate.
Yeh mate it comes up as a white 1996 R33 gtr.
He is advertising it as a 1996 GTR VSpec, does the FAST result say its an 1995 October build? :D
Also, does KLO, mean grey colour?
KLO is spark silver for the r33 gtr.
If you go here all the paint codes are listed. http://www.skylinesaustralia.com/forums/Ni...es-t138419.html
hey guys,
This is the VIN number i got off the rego sticker for my car:
VIN: 6T91MPV97P2WYW001
SN: 0407508
Is that sufficient information for you guys to do a check or do i need the number from the plate inside the car?
cheers :)
hey guys,
SN: 0407508
cheers :blink:
nah mate, you need the one on the firewall of the engine bay, it should read something like 6U900xxxxxxxxxx
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
