yea preety sure, mine is the same color KH2 ( looks gunmetal grey with red and blue 'perl'), the color code is actually on the compliance plate(firewall one, not import plate)), just above the engine type, RB26DETT . See port #1713, his paint code is KH2. This will confirm FAST info, and if the cars has changed color. KH2 is also refered to as gunmetal grey sometimes
PS midnight purple is a rare colour, price me thinks, codes are
LP2 (R33)Midnight Purple (no Chromalusion, has 2 pearl tinters Violet & Red)
LV4 (R34)Midnight Purple II (Chromalusion Tinter KK760 Absolute Purplene & Vilot Pearl)
LXO (R34)Midnight Purple III (Chromalusion Tinter KK700 True Blazberry Prizm & 2 pearls red & Violet)
see Here for ALL the Paint codes
cheers man.
i have no vin plate, and its definately midnight purple.
I'm Thinking respray job :)
could i please get mine fasted. 6U9000ECR33017453. thanks.
can I get a check on BNR34-006450 please
someone check this one out for me?
6u9000bnr32001624
Edited by BundyBear
got a japanese Nissan FAST DVD
installed it and when I clicked on nissan fast button it gave me parameter incorrect.
any tips how to install this thing on an XP?
Try this
README.TXT
or this
showthread.htm ^^^ Probably betta
Cheers
that's ok I found it. I need to change the font from the settings. it's missing jap font so it won't load up.
but now with Courier - it's still showing Japanese menu in gibberish so I might have to install a USDM front end and use it with JDM data.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
