Thanks any way, guess i'm going to have to pull it apart to see what's in there
cheers
no probs there tim, think I seen a 'swap parts 4 rego' thread somewhere on SAU, might B of interest
PublicEnemy : my version of fast doesn't do that Series but while FAST will let you look up the std diff part no it won't give you a ratio, I'd sujest ya local 4WD club
hey guys,
Ive tried looking mine up and it keeps saying its invalid.... i hope that doesn't mean there is something wrong..
VIN:- 6U9000 BNR32010583
Engine:- RB26012735A
I also thought the car was a full import due to japenese labels and fuse box and such plus i found yen and car action papers from japan under the seat. but reading the top post the begining of my VIN is aus??? hope you can give me some good news.
Cheers guys
hey guys,
Cheers guys
Naa nothn wrong thats just FAST, try shudown/restart on windows, helps sometimes
The 6U9000 tells you its a jap import(into Oz) 4 sure, unfortunatly Engine Numbers arn't covered
this is what mine got
looks sweet
Cheers
EDIT:: KH2 ==> Gun Grey Metallic
Edited by BundyBear
thanks bundy
i feel better now.... jus got it down to d workshop today to get it back on d road after 2 yrs! :)( finally!!!!!! YAY ;oD
are you able to do a sreen dump of fast?? i dont actually have the software. I have just tried searching it on other website and it keeps saying invalid.
Cheers mate thanks heaps
Edited by KrayzieGTR
hey would someone cluey with FAST please check a part number for me please:
My Vin Number is:
6U900BCNR33003083
(or use any late 32 or early 33 GTR vin)
Rear turbo drain outlet
like this one:
thankyou.
Can someone help a noob out and please fast this Vin for me.
ECR33104713.
This may be my first skyline and i would like to know as much as i can about it.
I have to make a decision on it tomorrow so speed would be appreciated.
Thanks in advance, Mat.
Edited by EastsideZero
My Vin Number is:
6U900BCNR33003083
like this one:
thankyou.
hey Nigel
I think this is what I'm lookn at ?? drains back to the side of the block.
used your VIN so you SHOULD get the right part, im no expert though
Cheers
ECR33104713.
hey Mat
look like a sweet ride
Interior colour 'K' = Grey
paint colour 'AR1' = Super Clear Red II
GST25TM1 = GTS25T type M, Spec 1
cheers
This says that it's KR4 (silver) however the car i'm looking at is white. He said it was resprayed back in Japan or something? The model number matches up though and he does have a current active rego...
Edited by RB25PWR
hey bundy,
if possible can you post a screen dump of the details you got for my VIN in FAST. i still cant seem to get them myself. it would b very appriciated.
cheers mate
hey Nigel
Cheers
thats the one!!!
cheers heaps!!!
=D
hcr32031256 cheers :)
mmmmm Type M,
Cheers
hey bundy,
cheers mate
kay
I'm assuming your having problems using FAST, which Version are you using?, do other VIN No'z work?
Did you get the PM I sent you??
Cheers
Hi all, i'm new to this forum and have put a deposit on a R34 GT-T today!.
Would someone be kind enough to check this VIN for me? (I probably should have checked before paying the deposit).
Thanks in advance for your help!
VIN: ER34012606
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
