The numbers I got given for the car I want to buy are:
VIN: 6T91MPAAATXBVW001
CHASSIS: BCNR33-002306
I may have to contact the seller to get him to resend
I tried again but it didn't work. Sometimes this can happen and it can work on other people's FAST programs. Can anyone else try?
Thanks.
Anyone know what the last box is on the left in the second last row? The one that states "GT-R.17
Gonna take a guess here...
All the R32 GTR screenshots I have saved are all non-vspec models except for yours. All the regular GTRs just say "GT-R" in that box. Yours is a vspec and says "GT-R.17". Maybe its referring to the standard 17" wheels as a way of identifying between a regular GTR and a vspec GTR.
The "8" (third last digit) in the model number signifies the GTR V spec II. Is there a possibility that it could be the build number off the production line? there was only 1303 produced.
Hmm I don't think it would be the build number. If I do a generic "R32" search in FAST, I'm able to click that button and it shows me all the models of the R32:
The ones we are concerned about are GT-R and GT-R.17, which both of them are there and there are no others saying something like GT-R.1000, for example.
So I then looked for a vspec vin number on google, searched it and it says GT-R.17.
Then I searched another vspec vin number to make sure and it also says GT-R.17.
So basically, I'm pretty sure its just a way to distinguish between a regular GTR and a GTR vspec by using the .17 as a reference to the standard wheels, as I said before.
Hope this helps :P
Hope this helps ;)
Certainly does Dark26, thanks for all the effort, appreciate it.
BCNR33-042666
please
BNR32012779 the car is pretty stock with all the nismo gear on it. can this programme tell if its an original nismo or a standard? ta
Apparently, Nismo GTR VINs start with BNR32-100XXX, and regular GTRs start with BNR32-000XXX, and yours starts with a 0.
Also, I found a Nismo GTR on SAU and the VIN started with a 1. Also, at the end of the model code, there should be a 'RA' which stands for 'Nismo Group A Limited Edition' but yours says LTZG.
Ah k shame, i really had hopes it was a nismo version lol. had the bonnet lip, the dash, stickers etc. And the car was pretty much stock. All it has is a cat back exhaust, pods and rwd switch lol. ah well thanks alot mate. shhh "ill just pretend its a nismo anyway" shh hahha
    • Oh ok that makes so much sense. Thanks for clearing it up!
    • And these modern "environmentally friendly" EV vehicles also run on the same smoke! When the engine, wiring, or batteries let it escape it also stops running!
    • Yeah - I found the same information too.. 30% open is like 85% of flow etc. So it's probably going to be minor if not completely imperceptible. I also have a larger pod filter here, will swap that on and see if there's any difference. The hardest part is finding a place to uh, test this. It's quite noticable just how much having ducting to the otherwise completely open pod cools the intake temps down. It's better boxed, or shielded but driving for 30 seconds really makes it plummet to near ambient temperatures. I recall in the past when I was a RB land and had a nice flowing airbox -  - Then I took the lid off and put a pod there, and gained 9 psi of boost and about 60kw from the restriction I didn't know I had - with the controller at same duty cycle. However finding people using over the radiator intakes having similar KPA drops at WOT on built setups makes me think there restriction could be the exhaust or potentially the headers. Either way though, there's no real estate to play with and nothing that can realistically be done about it. The original dyno plot without the airbox, and the larger pod had a better curve. It was later I added the ducting and airbox, and a smaller pod to make it fit in there...
    • That's not completely truthful now is it? Any flex fuelled factory cars also had the option to run on steam.
    • Yeah so I guess your mechanic would know turnaround better than me....but I would have thought you had access to same day or overnight rack rebuilds there....any big city here in Australia has that service.   There are a couple of o-rings and seals involved, I guess the risk is the part is specific not general. Other option is if you can have it on stands in your garage for a while, steering rack removal is pretty simple (2 mounting brackets, 2 ball joints (separate by undoing the nut to the top of the threads, put a pry bar between the steering arm and control arm to put pressure on it then medium force on the side of the ball joint or top of the nut with a hammer to break it free) and then the trickiest bit is the splines to the steering rack (not too bad to undo, one nut then it slides out, but mark it first so you can reassemble it straight)
