numbers as follows
bnr32-305104
kbnr32rbfs aa
engine no:rb26042943a
thanks in advance
This is a vspec.
Hey guys looking at another car
BCNR33-007187
Thanks in advance.
By the way is there a way I hold get a hold of fast either purchasing it or just download?
thanks
You could probably find FAST on ebay, but its usually someone downloading it for free and then selling it....just like the nissan manuals in pdf form. You can download it, shouldn't be hard to find.
nobody out there? i suspect my 1.6 gig copy of FAST will download before i get a response!
Pretty sure that FAST won't give you engine details.
For what its worth, the engine registry i have says the following, which means the engine seems like the original that came with teh car.
V-spec II Released: 14th February 1994 BNR32-300001 - BNR32-314649
R32 1994 July
RB26-042xxx
R32 1994
RB26-045xxx
R32 1994 July
RB26-042xxx
R32 1994
RB26-045xxx
this car is a vspecI u got any info on them much appreciated where do u find all this info?
Hey guys need this fasted to confirm its a genuine R32 Vspec II
BNR32-301556
Vspec IIs were made in 94, not 93
'X' should be a 'B'
'7' should be an '8'
'GT-R' should be 'GT-R.17'
FAST can sometimes be wrong so at least check if theres black brembos, although thats not a definite answer since they can be swapped.
Hi guys, not a VIN but can some one tell me what this is? A mate of mine is looking to get rid of it. Not even sure if it's really worth anything! Cheers!
From what I can tell it might be a 300ZX ECU? Came from a car running an SR20 with an after market turbo added...don't ask!
Z32 08/90 to 08/92 manual, vg30dtt
it was running the sr20??
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
