Ian
Sorry Bro but doesn't seen to be VSpec, should say GTR/V not GTR
cheers
Ouch, thanks Bundy Bear. I put down a deposit on it thinking it was a V SPEC, the speedo cluster is from a vspec with the active lsd light and the compressed tacho numbers.
Trouble is it can't be the original speedo so who knows what the real kms would be. Guess I had better try and get my deposit back.
The vin they gave me over the phone bnr34 005515 isn't correct. Just looked at a copy of the export certificate before I was going to ring and try and get my deposit back and saw the correct vin bnr34 005155. Could someone please fast the correct vin for me. Thanks
vin BNR34 005155
Could someone please run this for me
BNR34-402618
Just bought this but no idea if its a Vspec or Normal Thanks!
Sorry Mate
Mine won't accept that VIN (SOMETIMES happent with FAST)
If no one else's works then you best bet is to decode the model number or look at the options fitted to 34 Vspecs n compare yours
Easiest way to tell if its a VSpec is the $$$. if its cheap(ish) then probably not
cheers
Bundy
preety sure that:-
The 6th letter of your model no signifies Vspec or not
V = Normal GTR
W= GTR Vspec/VspecII
If the 16 th digit is an "I" then youve got an N1
note: the number you supplied is the 'VIN' number. The 'Model" number is on both compliance plates( along with most info FAST will supply + more)
Cheers
Bundy
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
