LOL
QM1 is white.
http://www.skylinesa...an-paint-codes/
edit: looks like that plate has a Q instead of a J on the fast? (model number)
And vin is missing a 0?
James, this is the MNP R33 GTR for sale in perth in Hocking. The one i posted in the thread "R33 GTR". On his carsales ad he has taken a photo of the compliance plate with the original vin # stamped in it.....
LOL
QM1 is white.
James, here is a screenshot of the plate affixed to the firewall of this MNP R33 in Perth. It has LP2 stamped on it along with the VIN number etc etc.
Hi could someone check the below VIN # for me please!
6U9000BNR32306428
As far as I know, it's a 1994 R32 GTR (non V-Spec), it's either Wine Red (AN0) or Red Pearl Metallic (AH3), not sure how to tell the difference.
Thank you :)
6U9000BNR32306428
Thank you :)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
