If it was originally a GTS4 (i.e it is 4wd) it would be ENR33. I tried them all this morning, and no combination would work.
F = CA18
H = RB20
E = RB25
B = RB26
C = Super HICAS
N = Atessa
R = Chassis
CHASSIS CODES
-ER -- GTS25
-HR -- GTS
-ECR -- GTS25t
-ENR -- GTS-4
-BCNR -- GTR
Yes, if it says ECR, it is a turbo chassis/engine. The brakes are different, the number of wheel studs are different... i'm sure there are many other differences. If you had a motor swap, and you have a DE (Dual overhead, EFI) then either the plate is wrong, or the motor was swapped out.
So... if your chassis was a turbo model you should have 5-stud wheels, a stronger gearbox (not sure how to tell, but it could be a manual-only thing), obviously you'd have no boost gauge in the dash. The side-mount intercooler would have plumbed through the engine bay via two holes infront of the air filter box. That should be very obvious.
Check those things? If the chassis has all non-turbo parts, I would *guess* there is something wrong with that plate. Strangely though, that plate doesn't belong to another chassis... it just doesn't exist. =-o
Let us know.
-Steve
OKAY well the brakes i have are slotted rotors? the wheels I have are SUPER ADVAN Racing Ver.2, all i can count is 4 studs? gearbox is auto, has 2nd/3rd/Drive gears, the intercooler takes up the whole front bumper? and has pipes going down each side of the front bumper? the air filter box is there but the rest of the CAI isnt..? its all been registered and been thru regency.. and im sure it is a turbo.. did you get PHOTOS to ur email????
F = CA18
H = RB20
E = RB25
B = RB26
C = Super HICAS
N = Atessa
R = Chassis
CHASSIS CODES
-ER -- GTS25
-HR -- GTS
-ECR -- GTS25t
-ENR -- GTS-4
-BCNR -- GTR
Let us know.
-Steve
a strange occurence i saw in the opposite direction was a series 1.5 96 model GTS25T 4 door. ER33 plate with RB25DET engine printed on it. full turbo everything but ER instead of ECR. strange ....
G'day mate could you check this vin it's meant to be a 1990 r32 gtr nismo gunmetal kh2 paint code
Vin: BNR32-100032
Model: KBNR32RXFSL RA
also if it's possible to find out If it had a/c and radio as I've been told that it was an option on the nismo
Cant tell you about the options, but its definatley a Nismo, if the chassis number starts with a 10XXXX, your particular one is number 32 out of 560?ish
Plus the model number ends in RA. Nice find.
Vin: BNR32-100032
Big ask! We need someone who can read Japanese, I think. ;o)
The specs:
F = Manual 5 Speed, S = EFI?, The L-M-A is your L-R-A
VS1 box = L... No idea what that says. There is no "R" that I can see, but the first item in VS2 is in Japanese.
"A" in the first box is also in Japanese.
More specs of LRA
Cheers Randy your a champ.
Yeah thought that might be a hard ask but there is a fair amount of info there I'll send it onto japan to a fella over there and see if he can get a translation of the japananese
Are you able to check engine numbers?
I have a rb26 with the engine number RB26-009627A
Trying to work out what it's out of. It's going into my 180sx. I've trawled the net for the last hour with no real luck and I'm only on my iPhone.
Cheers
Cheers
Sorry mate, can't look those up. I would think there would be some info on SAU somewhere though?
32's don't seem to have a series, but r33's had three series! The 33 oil pumps had a bigger locator or something. I'm sure there must be lots of little differences like that, that you could spot if you could find the info.
edit: My mate says late 32's had the stronger oil pump too.
That GTR mate of mine is quite helpful!
http://webbersrbguide.com/index.php?option=com_content&view=article&id=47:engine-number-register&catid=42:engine-number-registers&Itemid=2
Based on that (and I think more people should submit their engine numbers anonymously to this site), you have a REALLY early 32 GTr engine with the smaller oil pump drive. =-]
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
