Will need the Original VIN number off the Blue build plate/firewall mate. Pre SEVS copliance VINS like that can't be run through FAST. :)
Weird that the build plate is in Green... anyways i got the VIN here, hope it works
BNR34-003490
Hi there,
Could anyone please run an urgent search on VIN6U9000BNR34000553 as I am looking to purchase?
The model number shown on the Chassis Plate is GGJPRVYR34ZZAABJED.
Just want to check whether it is a standard GTR or V Spec and also what factory options were included if possible.
Thanks
Hi there,
Please help check out the info on this one, 6U9000BNR34401851
Thanks in advance! =]
Big Rear Brakes
Super Fine Hard Coating
Advanced Aero System
Privacy Glass
Rear Fog Lamps
Multi Display Meter
Rear Wiper
BNR32001477 please
Hey could someone please check this for me:
bnr34401380
Thanks in advance
Spec Codes:
Big Rear Brakes
Privacy Glass
Rear Fog Lamps
Multi Display Meter
Rear Wiper
Hey guys, can someone FAST thia one for me please?
6U900WGNC34135673
Thankyou
can someone tell me if my gtr is a vspec and the options bcnr021695
I think you're missing a few numbers, please check again.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
