I have the same MZG which doesn't seem to decode per writeups.
I do have the rear wiper.
I do have climate control
No clue on differential yet.
Can anyone help?
M = P+Q (Climate control (A/C) + Upgraded Sound (Sound System)
Z = Cold pack (Heated Mirrors)?
G = B+D (ABS + Visc LSD)
But since you don't have Rear Wiper / Climate Control... MZG should mean you don't have any of those... To save weight.
Your R32 is Gun Metal Grey and was built in Dec 1990... Signs point to a description of the Nismo Edition...
BUT! I am not saying it is... Can you find the Turbo Part numbers? Or do you know what Turbos you have on?
I have climate control
I have rear wiper
Stereo and all component s were missing when I got the car
I really don't know which diff (or diffs) are in the car right now but the factory service manual mentions nothing of a viscous diff in front or rear of GTR
I have ABS
Brakes are gold calipers Sumitumo up front (brembo?)
And grey calipers in rear
I'll check mirrors next time at the shop
Turbo part numbers are:
EA0138J
14411-24UD4
466071-6D
Edited by HarrisRacing
I have rear wiper
I have ABS
EA0138J
14411-24UD4
466071-6D
Ok cool!
I just realised I read your post wrong *Doh* >_< you DO have A/C / Rear Wiper and Stereo / ABS :)
So scrap the thing I said about Nismo.
You have a base model R32 GTR built in Dec 1990.
Stock Nissan brakes, it looks gold as they dark grey colour would have just faded over the years.
Turbo Part Numbers check out to be R32 / R33 GTR stock turbos (Both same).
Mechanical LSD was standard on the GTR's and Viscous was standard on all Turbo models, hence your R32 is Twin Turbo, it will have it.
And yeah, check the Mirror Switch.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
