Hey guys can someone fast this please. Should standard gtr have a number 7 at the end of the code? Its a 1992
What do 92 n1 body code usually look like?
Thanks
Your VIN is normal, how a standard VIN looks like.
N1's have a "ZN" not "AA" in the Model Number.
Can somebody please decode this for me
BNR32 310473
KBNR32RBFS8AA
thank you
V-Spec II.
Can someone fast hr33 005443 for me... it comes up in mine but without paint color??? Need to know what silver it is. Cheers in advanced
There were complications in you VIN.
Take a pic of you Blue Plate in the engine bay and post it here and let's have a look.
Pretty sure 1n4 is the paint but was wondering if my fast has an issue?? Guess we answered that...and yes the firewalls bent...along with a lot of the body...parts car
All good!
Ok here is it.
1N4 = Mixture of KL0 (Silver) and KM1 (Grey Metallic)
  • Like 1
Would someone be able to tell me BNR32 219723 please? :)
IF the model is KNBR32RXFS AA does that mean it's a V-spec due to no numbers at the end? Cheers
Yes but since your GTR was built in June 1992, it's only a Base Model.
V-Spec's were built in February 1993 onward.
Can you check what year is it?
thanks for help,
cheers
The Production Month of your GTR is March 1998.
Wouldn't be hat mean mine would be a V-Spec since built in June 1993?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
