You quoted another members (ER34sedan) VIN in which I did a search for.
That one's not for you.
That's my one.. 1993
Here is yours.
If it were a V-Spec, the Grade should state GT-R 17" Wheel.
Do you have factory Brembo Calipers on your GTR?
Your Model Number = KBNR32RXFS7 AA
The Grade of your Skyline is X = GTR 16" Wheels
The GTR Grade = 7 = GTR
The GTR Grade Continued is = AA = GTR & V-Spec / V-Spec II.
AA will be there regardless if it's a Base Model or V-Spec or V-Spec II.
So meaning, if you have a Base Model, it will state AA.
If you have a V-Spec and or V-Spec II, it will still state AA.
Would you mind checking my 32
BNR32-001148
Also would it be possible to check my STI?
GDB-037648
Thanks
Josh
Can you please check whether my Stag is an Autech? After browsing forums on this topic I'm starting to think it might not be.
6U900WGNC34103968
I'll be forever in your debt.
Cheers.
Zane.
Grade = 260RS = RB26DETT (Autech)
I always thought all 260RS were all Autech's..?
Yeah that's right I just wanted to make sure mine is a 260RS and not just a RS4 with a RB26 transplant.
Thanks mate my mind is at ease. :)
Yeah all good :)
You got the front and rear Brembo Calipers too?
You don't see a Deep Marine Blue coloured R33 GTR V-Spec all that often.
ty so much shes left hand drive 41k kms with an
hks step 2 2.8 kit
n1 block
hks 272 11mm lift
gredy intake
titanium midori exhaust
twin gt2871rs on n1 manifolds
greddy fmic
r34 getrag 6speed
hks twin plate
ohlins 2way suspension
hks pro suction kit
reinix oil pump
haltech pro plug in
trust oil pan with baffles
auto select front carbon lip and canards
nismo roll cage nismo
lm carbon rear wing
and a real nice defi gauge display
on volk te37s 18x10 +12 offset shes a looker and a killer
hks step 2 2.8 kit
n1 block
hks 272 11mm lift
gredy intake
greddy fmic
r34 getrag 6speed
hks twin plate
hks pro suction kit
reinix oil pump
haltech pro plug in
lm carbon rear wing
Nice!
Who built and tuned it?
What's the power out put?
:blink: Left hand drive?!
Nice!
HKS built it i freshened it up with a some new acl bearings and a new set of hks step 2 ti piston rings cost me 400 used the set, as for the tuning i live in peru soo me and my mate tune it we get by on our own my last rb26 dyno'd 830rwhp at 2.5bar out of a billet 67 mm borgwarner turbo with pump gas and meth injection, goin for 750awhp also have a brand new t04z kit i might put on if i dont like the twin setup here are some pictures of the car in the shop and its first time out still gota paint the bumper on it but man is she a looker
Edited by Regan2860
Wow! That's interesting and left hand drive looks so funny... Cause I am so use to seeing right hand drive Skylines :laugh:
Good on you for doing it on your own with your friend.
HKS always do a good job.
Looks like it's making some decent power.
I prefer the twin setup myself but see how you go.
Thanks!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
