10 hours ago, JB4U said:
Thanks!! Series 3? No idea how to read these haha
Certainly not the '95 in your profile hey!
FAST is the source of all truth but Mark pulled all that info and put it in the form of http://gtr-registry.com.
You can bang yours into http://gtr-registry.com/en-bcnr33-vin-table.php and you can verify that it is indeed a s3, and all the option codes from FAST are translated too. (large front spoiler!) =-D
  • Like 1
Sweet! Thanks man! Looking at buying it but wanna make sure all is in order before doing so!
21 minutes ago, DaveO74 said:
Thanks Randy,
So do you know what the model is telling me?
6th digit is a "Q", which apparently is not a S or PS. It would also have 18's rather than 19's?
  • 6 months later...
41 minutes ago, borka1975 said:
Can some one do a FAST check on my 32R
model: BNR32-221852
any info would be great, Km traveled in Jap (last rego check) options included etc...
thanks in advance
The FAST system is just Nissan's build database, so it only shows how your car rolled off the production line.
You can check the options decoded from the "Model", but GTR registry has already translated it all for you.
Thanks Randy, not clear on the blank between the S and AA ,GTR registry quotes V-Spec 17" Tyre but X clearly states its a GTR not a V-Spec
only 3 V-spec's in 09/92 as per GTR registry?
what's your take on that info?
cheers, bob
cheers, bob
I imagine it's just a 17" wheel option that the V-Spec gets by default. Just a guess.
cheers, bob
Hey Bob,
Actually the text in http://gtr-registry.com/en-bnr32-vin-table.php#OptionCodes was slightly incorrect as I had series 2 and 3 combined and yet the code for the 11th digit is different for blank for series 2 and 3.
I've split them up into their own sections and adjusted the text accordingly, so it is more accurate and clearer. Thank you for posting this.
On 3/27/2020 at 7:04 PM, sin- said:
Hey Bob,
Hey Mark,
Is this now 100% correct or we think it's 99%?
cheers Bob
  • 3 months later...
7 hours ago, PriceyENR34 said:
Hi guys I've been having troubles trying to find out the year of the rb26 that went into my enr34
engine number is
rb26034074A
Just wondering if someone could look it up for me?
I don't think that's possible to look up without the VIN of the car it came from.
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
