VINS you want "fasted"
46 minutes ago, Die$eL said:
How do I do that?
Ah I was thinking of another forum. SAU does something else with the reputation points. NO matter =-]
  • 3 weeks later...
On 7/12/2017 at 2:04 AM, drunken0elf said:
Cool thread.
Here is mine, it was color changed  before I bought it, so never knew the original color.
BNR32214386
Cheers!
TH1 = Dark Blue Pearl
I just saw your thread, you would have seen TH1 in real life as that's what colour your car was / is LOL!
https://www.sau.com.au/forums/topic/471403-your-favorite-r32-color/
It got colored changed before I got to see it in it's original color, so I've never seen th1.
As mine was produced in late 1991, does that mean it's got the better oil drive thing?
Edited by drunken0elf
From memory, the improved oil pump drive collar was either done on the later model R32 GTR's or in the RB26 on the R33 GTR's
It only failed with high power applications but if you running for street, low to mid power, you will be good
Unless you do a full rebuild, you would install the improved oil pump drive collar
Hi,
Can I please request mine:
HR31-067403
Pretty sure it may have been auto originally but I have to know!
I can't figure out how to get FAST to display the characters correctly on my machine.
Thank you
6 hours ago, The W said:
Hi
Could someone please tell me if my engine is the original one it left the factory with please?
VIN 6U900WGNC34105861
Eng RB26053432A
Thank you!
Hey man.
As far as I know the engine numbers weren't tied to the chassis, so there wasn't any way of knowing if it was the original or a swap. All we could tell you is whether it's the engine is the right kind.
That being said, i'm not sure how to look your Stagea? up? It doesn't work in my versions of FAST.
5 hours ago, Raucous said:
Hi,
HR31-067403
Thank you
Manual!
Possibly need to change your font in the setup to Japanese script. or edit your nsfastky.ini file to english:
[Condition]
Destination=DM
Channel=1
Language=ENG
FontName=Courier New
FontSize=10
  • Like 1
1 hour ago, RANDY said:
Hey man.
Thanks :) that actually helps heaps.
10 hours ago, The W said:
Thanks  that actually helps heaps.
No problems mate!
Here it is for you anyway, and you can get some cool extra info and links for the Autech Stags from Marks (Sin-) web database: http://gtr-registry.com/en-stagea-260rs.php
If you bang your VIN in there you get:
  • 3 weeks later...
    • Thanks for all the replies! I also wanted to ask if wheels that were fitted on Ford Falcons would fit the 350GTs as well? In the area I'm at there aren't that many options for secondhand wheels and new ones here are way out of my budget. From what I've seen, most of the wheels that are available that were fitted on Ford Falcons have an offset of +33 to +36, with a centre bore of 70.5mm whereas the stock 350GT's ones are 66mm, can't seem to find any hubcentric rings that fit that difference though.
    • 215/45/18 tyres are probably a little on the low side compared to the factory tyre, it should be closer to a 245/45/19, which will get you about an extra 11mm of height, and should make you speedo read a bit closer to reality. 245/45/19s will be a bit too far the other way and you risk a speeding ticket as your speedo might read slower than your actual speed.  245/40/19s would be correct if you are going to 19in rims, they will give you a similar total diameter to the 245/45/18 tyres.
    • That's something I forgot to put in my list. The aggressive anti-squat in R32 is a f**king menace. I still need to decide if I'm going to drag the subframe out of my car and weld in the GKTech corrector kit. The main reason to dither is the need to switch to spherical joints in the lower arm to account for the twist induced in the rear pivot caused by lowering the front pivot. And yes...we do put better subframes in R32s, and I wish I'd gotten an S14 one instead of an A31 when I did the "take off and nuke it from orbit" HICAS delete all those years ago.
    • I have been looking at some setting on the alarms for the Q60 and what buttons do and so and also been looking for details on the alarm in my V37 which is a standard issue with the car. settings like window roll up and a few others seem to not work at all. i cant seem to find exact info on V37 alarms so Q60 is all i can really go off i have not tried 400Z alarm settings or info yet so that will be next. any one got like a sheet of info on the alarm system in the V37 as all my documents are in japanese but i thought the system would basically be like standard through similar models?
    • I had a fuel smell coming from the drivers rear and pulled the tank out to inspect where it was coming from, turns out the breather hose from the tank to the filler neck was perished. I’m going to Japan next week and I’ll grab it while I’m there  pulled the oil tank apart and started cleaning this crap out of it, some brake cleaner and rags got it looking new again
