VIN: 6M91MPORT12TG0024
Please and thank you
hey mate, not sure how to input that vin... please look for a number that starts with something along the lines of
bnr32
bnr33
bnr34
hcr32
ecr33
etc... usually followed by a nymber... for example ecr33 003544
Hi all, noob here that has a GTR with the vin bnr32001455. I have downloaded the software but when I try to install it my computer crashes, maybe coz I have windows 7 beta installed.
Anyway if someone could run the vin for me I would really appreciate it.
Thanks Ruffels, do you know if FAST can tell if it is a "Mines" optioned car or were these all done after they left the factory?
My car has a Mines boost gauge in the centre dash and a mines ecu and I will have a better look to see what else has the mines label.
Thanks again, Tony
Hello everybody I`m from Germany and nobody can help me in Europe ,GB, USA
This is the VIN of my car BNR34400109
Its a November 2000 build R34 in Bayside blue what I`m not abel to find out is the original engine Number belonging to the car..
Can anybody help me......?
Thanks!
Gotta do this one ^^
Its from the fast and the furious (Paul Walkers old car). No Joke!
http://www.skylinesaustralia.com/forums/As...ce-t290760.html
Yeah you got it I also bought two other cars from the Movie a red R 34 and a red R35 (left Hand drive) I`m going to sell one of them if anybody is interested just let me know :whistling:
Edited by Tax66666
LotusGTR - BNR32 220675
Model: KBNR32RXFSAA
Series: R32
Produced: 08/92
Ext Colour: AH3
Int Colour: G
2K
RB26DETT
HI.4WD
GTR
MT.F5
___________
Tax66666 - BNR34 400109
Model: GGJPRVYR34ZDAAGXBD
Series: R34
Produced: 11/00
Ext Colour: TV2
Int Colour: G
2K
RB26DETT
HI.4WD
GTR
MT.F6
Model: KBNR32RXFSAA
Series: R32
Produced: 08/92
Ext Colour: AH3
Int Colour: G
2K
RB26DETT
HI.4WD
GTR
MT.F5
___________
Series: R34
Produced: 11/00
Ext Colour: TV2
Int Colour: G
2K
RB26DETT
HI.4WD
GTR
MT.F6
Thanks a lott, but I can`t find a engine Number ??
Is it possible you find out??? :)
Sorry for the hussel but that is what I need.
Thanks Mr Ruffels. I'm buying this one today so your efforts are not in vain.
Model: KBNR32RXFSAA
Series: R32
Produced: 08/92
Ext Colour: AH3
Int Colour: G
2K
RB26DETT
HI.4WD
GTR
MT.F5
___________
Series: R34
Produced: 11/00
Ext Colour: TV2
Int Colour: G
2K
RB26DETT
HI.4WD
GTR
MT.F6
Model: KBNR32RXFSAA
Series: R32
Produced: 08/92
Ext Colour: AH3
Int Colour: G
2K
RB26DETT
HI.4WD
GTR
MT.F5
___________
Series: R34
Produced: 11/00
Ext Colour: TV2
Int Colour: G
2K
RB26DETT
HI.4WD
GTR
MT.F6
10 :P
This is funny I can`t reply to someone before I got 10 Posts????
Why that......
But O.k
9
It is so spammers cannot just come on here with brand new user IDs and spam the crap out of everyone like they were doing a little while back .... it is the same reason we implemented flood control to limit the amount of PM's you can send in a specified period too.
It is so spammers cannot just come on here with brand new user IDs and spam the crap out of everyone like they were doing a little while back .... it is the same reason we implemented flood control to limit the amount of PMS you can send in a specified period too.
Thank you for the info. I hope you would not mind that I found a solution for that Problem :P
no problem guys, unfortunatly engine numbers are not on the listing... it might be possible to dig it up somewhere... but i am unsure how.
That would be fantastic :)
I got a big Nissan Dealer here but he was not abel to track down the engine Number.
I only need it to find out if it`s a "matching Numbers" car. The yanks are not so good in doing paperworks and everybody just "forgot" two write down the engine Number when they bought the car in Japan. After they build so many cars for the movie and all of them where diss-and than reassambeld I just want to know if the Engine is the original one.
Thanks a lot upfront
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
