Here's a problem I may need opinions on, while I look for a fix.
Car: ECR33, runs Apexi PFC and FC Datalogit. High flow turbo, stock manifolding. Injector upgrade to S15 Silvia spec.
I installed the injectors yesterday, entered the correction factors via Datalogit and car started straight up, no issues with running that I could tell. Took it for a short run this morning to check for fuel/water/air leaks. All nice and tight that I can tell.
Problem came up when I stop and engage clutch. Revs drop down to about 900 (normal), and then come up to a stable 1250-1300. This happens when a/c is OFF. When a/c is ON, revs drop to about 900-950 (stable).
I'd considered a few potential causes.
Vacuum leak. Inlet manifold has to be split to access injectors, and throttle body removed. Machined faces were all cleaned up spotless prior to reassembly, I used copper spray gasket to further aid sealing, and the manifold bolts were all torqued down in sequence (and a bastard of a job it is too). There is no obvious hissing under vacuum or under boost. The car also responds to a throttle lift, so I think (hope) I can discount air leaks.
TPS adjustment. Didn't touch it. Should be operating same as before.
Idle adjustment. Didn't touch the throttle body other than use some carby cleaner around the butterfly. Didn't do any electronic adjustments via Datalogit. Should all be operating same as before.
ATM, I'm going to have a second look at the inlet manifold bolts for tension, similar for throttle body bolts.
Any ideas on where else to look?
cheers
Dale
Edited by Dale FZ1
BUMP
Are there any opinions or experiences amongst you? I'm looking to fix this one myself.
Many guys have reported doing injector upgrades, so have there been problems like this one?
I can't identify any loss of boost, or decreased vacuum @ idle.
I've been considering that my correction factor was incorrect, leading to a rich mixture similar to cold-start correction. Going to do a short test by altering the correction slightly.
First test I will do is alter idle speed setting in the ECU and see how that impacts things.
comments?
BUMP
I made a slight change to injector lag, with no effective change to idle.
Then I went into idle control, altered the FC1 / FC2 values and got a hunting idle (rolling up/down between 500-1000). Made me remember that I had used carby cleaner in the plenum to purge oily film from the PCV feed. The AAC valve was left in-situ, and I suspect it may have got a coating of the oily crap. Going to have a look at cleaning it tomorrow.
Surely someone has some idea here?
just by chance did you disconnect the battery? may have to do a thorough idle relearn?
u say you split the manifold? is the iac reconnected at the firewall end of the manifold?
Didn't disconnect battery for the job - didn't need to. And yes - I know the manual says to do so, and the potential issues with sparks when the fuel rail is disconnected. Working in a well ventilated area, and I had control over the keys at all times.
To do this job, the manifold has to be split. It is the only way to access the fuel rail and injectors.
All connections put back together and double checked for proper attachment.
Edited by Dale FZ1
Think it says here to let it idle for half hour to learn idle
http://members.dodo.com.au/paul/docs/power...powerfc-faq.htm
Thanks Brett; appreciate your thought.
Self learn idle really only applies if the ECU has been removed (my understanding). In this case, all I did was disconnect the sensors that feed info to the ECU, laid them aside, and continued with the removal of plenum and fuel rail. At the end of the procedure the plugs were reconnected.
I don't think that it (ECU memory wiped) would be the cause, because my idle is stable - it is just a couple of hundred rpm higher than previous.
I removed the AAC valve assembly from the plenum today. There was some carbon deposited through the air channels, but not caked in or excessive (that I could tell). Used a fair bit of carby cleaner to loosen up anything, then blew it out with compressed air. Also removed the AAC solenoid from the assembly, cleaned up everything I could realistically get to.
Result: no significant change. Given what I saw, I didn't expect much different. The idle quality DID change, but inconsistently. Coming to a halt and engaging the clutch, revs would go down to about 800, climb to 1200, then hunt for about 10-15 seconds between 500-1000. Typically this seems to be related to a crappy carboned up AAC. Not sure on that one given that I had just put a reasonable effort into cleaning it out.
Further effort put into reading the engine service manual, and I found there is a manual adjustment on the AAC. Pic below shows it circled, viewed from the drivers side:
Following the manual, a clockwise adjustment of the screw did pull the idle revs down. A test drive showed the engine would come back to an idle within spec. Will have to drive the thing for a few days and see if the fix is satisfactory.
Has anybody found this sort of fix useful/workable in the past?
Its not the right fix - your only masking the problem.
Dale,
When I dropped my larger injectors in I initially had a few issues with idle.
I'm thinking I stuffed up the learnt values within the pfc upon the initial start as I forgot to connect the carbon canistors vacuum feed, resulting in a high idle. :)
Once connected the idle was all over the place and wasn't going to settle down, init and idle reset was the only thing that fixed it.
The ONLY solution in my case, get the pfc to relearn idle:
Disconnect the aac plug and reset idle to as close but not over the target set within the pfc, I then had to init the pfc and let it do its idle thing.
My PFC won't do the idle relearn if I disconnect the battery etc, it's still niggly with the high idle etc, but once done the above it was perfectly fine.
At a later date my carbon canistor crapped it, I could hear an ever so slight whistle from the carbon canistor, upon replacement it once again stuffed the idle required an idle reset.
If left untouched it does idle ok and learns a little but still has the odd high idle and hunt which gets under myskin, once an idle reset (manual adjustment + init then learn) it idles 100% perfect all the time)
yeah ive heard of that problem too
hanving the hand controller unplugged helps wierd problems
the hand controller sucks off 5v to run itself, maybe you have a voltage problem ?
Rob - didn't touch/adjust/bump the TPS. I will check my throttle closed voltage to be sure though. And yes, I am concerned that giving the AAC a thorough cleanout and adjustment is only a gloss over whatever the real problem is. At least it seemed to work.
Blind Elk - yes, as per original thread starter, I entered appropriate correction factors for the larger squirters. If not, it would be richer everywhere by a factor of about 18%
Cubes - although it was only the vacuum ports, AAC and TPS that were effectively disconnected, I will have a go at a full idle reset / ECU re-learn. I find it odd because there was no mechanical changes done other than installing bigger injectors, and no electronic changes other than specifying the injector correction factors. The ECU was not disconnected or power source removed. I will firstly run it for a few days with the current AAC clean/adjust, then have a go at full idle reset and post up any results during the week.
Paul - the hand controller has been disconnected at all times other than for a short run to see the difference in duty cycle. As expected, it was reduced by a factor of slightly less than 1/5 for similar running as with the original injectors.
The whole situation has been a bit odd but I reckon not something that has to be tolerated.
Thanks guys, the input/feedback has been helpful.
cheers
Edited by Dale FZ1
Looks like I have fixed it. Got a couple of pics for posterity too.
I'm going to run it for another day, then post up the outcome. Looks like it was related to attention to detail rather than any glitches.
After checking out the amount of adjustment I needed to make in the air bypass, I was satisfied there must have been an air leak somewhere/somehow. Note that there was NO noticeable loss of boost, or any hissing to indicate such, nor was the vacuum at idle lower than normal, nor was the idle rough.
Suggested method of tracing an air leak is to run the engine, then get a fine misting spray bottle of water to mist water around the manifold and injectors. If the engine stumbles while doing this, it's a fair indicator of a leak. Alternative is to spray some ether (sold as Aerostart or Start Ya Bastard) in the same areas, and watch for the idle speed to lift higher. Be careful using ether because it ignites easily. No good having an engine bay fire.
I re-split the manifold, and though the gasket seal looked perfect, I did find something:
The circled areas show where the inside bolts go. Note that one has a rubberised locator/isolator missing? It came out with the bolt upon disassembly. When I had originally put it in, things had not gone "home" properly. I must have been in a little rush just to finish the job and failed to see this. Then when I went to check the tension on all bolts, I gave it a little tweak with the spanner and felt it suddenly seat home. I presumed the seating was in fact yours truly stripping the thread and got very cranky. I had expected to need a thread repair job while redoing my work. (thankfully there seems to be steel thread inserts used by Nissan, so it would take one hell of a lot of tension to strip things out).
When I reassembled the manifold, I did it with perfect daylight, checking things 3 times.
Result: final adjustment of the AAC ultimately returned the bypass screw close to where it had originally been. Stable idle, about 700rpm at operating temp, about 900 - 950 from stone cold. Also I haven't gained any additional boost or vacuum. That leak must have been very very small.
There has been a lesson in this one, shows why some of us are mechanics and some aren't.
cheers
Dale
    • Hello First, I apologize if this is not the correct forum. Let me know and I will move it to the correct one. I'm having a problem with the tachometer on my Skyline R33 with an RB25DET Neo engine. I'll tell you from the beginning. I'll tell you from the beginning. I have the RB25DET Neo engine installed in a Nissan Patrol GU, with a Link G4X control unit specifically for that engine,  and I have fitted a Skyline R33 tachograph to the original GU dashboard, but it doesn't work properly. I have the tachometer connected to the positive and negative terminals of the GU panel's wiring, and the signal cable is connected directly to the ECU output pin, but the rpm fluctuates widely. Can anyone tell me if the output signal from an R33 ECU is the same as the output signal from an R34 ECU, or if the voltage and signal type are different? Regards and thanks.
    • I guess it was the thought about "Oh if I were to drive this everyday". Then no, SL500 I wouldn't really consider lmao.
    • Yeah actually really fair point. Idk what I was thinking when looking at the SL500. Now that I think about it, I feel like I would have more enjoyment out of a shitbox that I would need to repair than some fancy merc. Although I must admit the SL500 does look quite nice. My bad hahaha.
    • 100% Also "Not wanting to spend money" is THE WORST IDEA IMAGINABLE when coming to a project car of any kind. They EXIST to BURN MONEY. Sure, gas money is a thing. A stock car with the worst fuel economy ever sold would probably be cheaper than modifying a car with FREE petrol for the life of your ownership of it, lol.
    • Amount of time you're being observed by law enforcement is so minute, that you could be a dumb shit 90% of your driving time, and never lose a demerit. You could also be the best driver ever and still get hit with a fine.   When you realise how quickly everything turns from "Wee, we're having fun!" To "oh f**k oh f**k oh f**k", you start to realise the only way to be a good driver, is to not be doing anything dumb or unexpected by normies on the road. You want to go fast, go to the track. Someone there in a 1990s slow POS will also show you how bad of a driver you are as they lap 10 seconds per lap quicker than you can in a car that should be considerably faster.
