LOTS OF PARTS? TURBO VL BITS ,motors,gearboxes ect
located in victoria
pm for details
will post at your cost
hey i have a lot of bits and peices for sale here is the list
Rb20 botom end, no oil or water pumps $50
rb25de botom end,complete. high vol oil pump, good pistons,4wd giff and sump. purfect for that high comp (11-1) vl (rb30e) n/a motor or speedway motor $300
rb30 botom end n/a suit rebuild $50
rb 30et turbo botom end, balanced blueprinted,new rod bolts and re-bushed rods. new water pump (rb25det) all parts new or rebuilt.and all crack tested.20 over ceramic coated hypa-tech pistons, 10 over conrod berings and std berings crank all acel race berings, molly rings. just needs assembly $700
.302 cleverland needs rebuild 200
blue 202 $40
turbo c rods and pistons not sure of condition 50.
vl head unknown condition $40
polished N/A rb30e inlet (top half) $120
Vlt New injectors in n/a manifold botom 300
vlt loom suit manual 150
vlt computer suit manual/ have auto 1 to so if u want 1 just pm me offers.
vl manual comp also would have an auto 1 20 each
vl t exhaust manifold no cracks not warped 300
vlt cluch fork $10
vlt fuel pump used $50
vl head lights and indicators SOLD
2/12 inch de-cat pipe, (2 1/2 inch pipe with flanges with a cat body so the police cant c that its not there) $50
2 1/2 inch turbo dump pipe suit vlt $50
2 1/2 inch resignator $20
various turbo lines suit vl turbo $50
vl boss kit and crap stering wheel $30
sas lether stering wheel (3 spoke) not bad nick $30
vl rear bar suit vk also $40
6 roh 15 inch mags 5 spoke $150
vl auto and turbo converter SOLD
auto technica seats and harneses SOLD
lotsa interceptors not good ruber 20 each.
small front mount intercooler 300*600*80 $100
some vl cooler pipework with extra injector mounted $30
N/a vl 3.45 diff, drum, $60
3.70 ratio locked diff suit commodore. $250
XF lsd diff 2.77 disc brake $ 50
tihink there is another 1 with 3.45 ratio suit xf for $50
XF giah wheels 15 inch *5 resnable ruber $60
xf fairlane wheels $30 there is 4
xf indicator stork $20
vl blue interior parts , door trims,hood lining, dash pad ect blue/ grey in coulor $20
235/60/15 drag radials 7 passes old on 15*7 inch commodore alloys 460
gen 3 engine cover $50
roling vl body shell with some parts green in coulor $150
XD fairmont giah wrecking: electrics 302 clevo, fmx auto, lsd ect.......600 for the car or will wreck, verry rusty.
lots of other parts various v8 parts to suit ford's just msg me if u want anything and ill ask my dad if he would sell it.
vt alloy bull bar $ 30
Vlt 3 inch dump pipe.
rb25 de startor motor $50
rb25de alternator $50.
rb25det exhaust manifold $50
rb25de exhaust manifold offers.
rb25 de intake manifold bare offers
also lotsa other vl parts avalible and posible xd, xf and vl parts........
located in victoria and will post to you at your cost.
also eoi on vlt mx7 been rebuilt 20,000 km ago max with 330 kw rated clutch. all the bits to convert.
https://www.sau.com.au/forums/topic/128867-lotsa-turbo-parts-for-sale/
pm sent for:
cheers
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
