  • Replies 59
Posted Images
I would add that;
1. pineapples allow you to adjust the angle of the rear subframe itself for more or less squat/traction, changing the bushes doesn't.
2. pineapples are DIY, $105 in parts and 20 minutes to fit, the hardest part is jacking the car up, sticking the axle standards under it (for your safety) and taking off the wheels. Chenging bushes means removing the whole subframe and using a 20 tonne press ot remove the standard bushes, not exactly DIY.
:ninja: cheers :)
Hi,
Never tried both at the same time. Go pineapples if your bushes are ok.
I replaced my bushes and didnt really notice much difference driving normally. Normally only the front silicone filled bushes behind the doors wear out, the ones at the rear are solid rubber and they still will hold the subframe reasonably well in 'granny' style driving.
I really only noticed the back end moving around when I hooked into tight corners and accelerated hard out of them, there was a bit of squirming then, this dissappeared once the bushes were replaced.
Rear end felt quite tight, not sure if you are going to really notice the addition of pineapples unless you got serious horsepower or are drifting which could put enough stress on bushes to get some movement - although the Noltec urethane bushes are pretty damn firm.
Nice plus was that I didnt notice any extra harshness in the ride with new bushes, and neither did my mate when he did his gtr either.
This might change if you have harder springs, as you will be running out of components with some compliance in them to absorb some of the road bumps.
My advice if your bushes are stuffed and you are going to keep the car and drive it hard, replace them. Its a big job to do yourself and expensive for someone else to do. You can always add the pineapples later - which is not supposed to be that big a job to do.
P.S.
Taking the bushes out is easy enough, don't need any presses at all but will take 3-4 hours excluding the time to remove the subframe.
Just get one of those cheap flexy holesaws and a grunty drill and drill the rubber out - you might have to come at it from both sides to cut right through. Then bash out the steel insert in the centre.
Then hold subframe steady and hacksaw the thin bush casing. You can do this without any blow torches at all. The casing will pop out easily once you release the tension by cutting right through it.
Not a one day job and the hardest bit is the hacksawing but you will save yourself in excess of $800-$1000 in labour. This job is even easier if you don't have the 4wd system to bleed. Don't detach the hicas, just hang it out of the way with some tie wire.
You need to be careful lowering subframe as it is fairly heavy- best if two people do it, I did it by myself. I have a doc on this process - will put it up someday.
Edited by gts4diehard
ah k. so there is no real performance difference between the noltec urethane bushes and say whiteline pineapples then? if i were to go pineapples, i would leave the subframe neutral, and i work in a workshop so have access to hoist and other stuff.
just wanna know if it would be worth it to have noltec bushes.
my current subframe bushes are fine at the moment (not rooted)
Edited by salad
http://www.skylinesaustralia.com/forums/in...p;hl=pineapples
Have a read of that thread and draw your own conclusions.
EDIT
I just noticed that a pic of the whiteline setup doesnt work in that thread.
Luckily I have a copy :miner:
a few things to note -
any car (skyline is now what 14 years old??) with bushes that old are either stuffed or on their way out.
If you drive your car harder than just doing normal street driving, then chances are you will notice a difference in fitting new bushes.
No job is too big if you have the time and patience.
Do jobs right the first time, dont use band aid solutions. Only time id use pinapples, is for tuning the angle of the subframe as per Sk's comments.
I would fit the bushes to your car if u see any track work at all.
hmm, yeah, i was also thinkin that the pineapples were just a 'bandaid'.
i will most probly leave the bushes in the neutral (all round) position, so this probly means that noltec bushes are the best idea...
car sees usual drift practices and comps, and will be goin to circuit days soon
will pineapples still do the job if the stock rubber bushes are rooted?
how do you know BeeR make quality stuff? have you ever seen or used BeeR parts? personally I would say some of the BeeR parts are not as high standard as the really nice japanese parts like HKS, ARC, RAYS etc. They do make some cool stuff but I dont think they are renowned for high quality at all.
Good thing I came across this thread. I'm in process of doing a suspension makeover for the GTT and was thinking of getting the front castor/radial bushes, front and rear camber kits and already have the Noltec subframe bushes from the GB (thanks Bl4cK32 - trader rating on its way).
Since I'm already planning to order stuff from Whiteline I was wondering if I should pay the extra $120~ for the pineapples or not? Would I see much benefit from the pineapples if I already plan to fit the subframe bushes?
Also, any idea how much I should be looking at to get front castor kit, front and rear camber kit, subframe bushes and coilover height adjustment? Or should I give it a go at doing it myself and just pay for allignment - if its possible?
Cheers all,
Andy
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
