Yeh so i got canaried a while ago for having "racing slicks" on my car (were in fact SPMAXX's, slightly low on tread but still legal) Got that cleared, now the fugn canary won't come off. Ive got the majority of the paper off, but the underlying sticky stuff (sticky paper) and the glue stuff wont come off.. Ive tried, petrol, metho, scraping, nail polish remover and eucalyptus oil and besides getting high, had no success.
Any one got any other suggestions on how to remove it?
I was thinking of paying the $ to get it professionally cleaned and forwarding the bill to the victorian police or vicroads, any one reckon this could work?
https://www.sau.com.au/forums/topic/129498-removing-a-canary/
If you can find it (not sure what shops to buy it, we have it at work) but 3M have a product called Goo remover it's in a red can, it's the shit for removing anything sticky from anything :dry:
As for forwarding the bill to vicroads no I doubt it will work but it's worth a try :)
Edited by Omurru
Also that fat dude big kev had a goo remover thats good. theres a couple of options you can use.
* Brakkeklean by CRC will remove almost anything (good tip : this gets almost any car related stain from clothing, grease, oil and brake fluid).
* Citrus Oil Spray : the cleaning power of citric acid is amazing.
* Prepsol or Tryco fluid - these solvents work a treat.
There ya have it. I would be trying Brakkeklean 1st.
if you soak the back of it for 5-10mins it will come off.
Get a sponge, wet it, press it against the sticker.
Do this probably 5-6 times as the water will run out of the sponge... warm water also helps.
And then it will just peel off, and the glue should just wipe off aswell
ahh ok did the water method with a cloth for like 10 minutes (first time i tried left it only like 1 minute), now alll i got is a sticky residue and a couple of little bits of paper, will try some wd40 to get thar crap off
Err and are big kev products still around now? He died of a heartattack a few years back
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
