Hey guys,
After a chat with a mate regarding tunes etc, just want to klnow what others have done!
Ok, so you have done the basic mods - exhaust, fmic and added a bit of boost with cold air/filter.
Now - have most of you guys left as is or decided to play it safe and go a tune to make sure all the AFR are right and such n such and making sure its not running rich or lean when boost comes on?
Because so far i have just done the basic mods as said earlier - and it got me thinking, am I going to destroy my motor later on by not tuning it for safety not just out right power?
Im not that smart with turbo motors and boost - my experience has been with LS1 motors!
or am I just being paranoid???
Cheers,
Chris
https://www.sau.com.au/forums/topic/129630-those-who-have-tunes-and-havent/
there are also things that you can do before you get a dyno done to help richen up the afrs (but results vary). first of all is to clean the afm. if its dirty then it isn't reading the correct amount of air and can make the car run lean. you can also check the fuel pressure. it is better to clean the afm before the dyno run, as you don't know if it will have any affect and then atleast you can see what they are like when its clean and if it is still lean thats 1 thing that you can cross off the list.
Hey Chris
Provided you don't do anything too silly, like run 30 psi or something, just the standard mild mods on stock turbo won'nt destroy your car, it just won't drive much better than stock, that's all.
On my car, i've done everything but the ecu, and i get big rich and retard. When that kicks in, it feels like I get pulled back. there's a big dip in power. so It doens't feel, nor is it actually very quick.
I reckon either do all the mods + tune, or just leave it stockish
nah im not that silly :thumbsup:
basiclly its on 7psi 90% of the time and then if i feel like it switch it to 11psi
Im just thinking now - perhaps I should get a tune to keep the motor safe - however buying a powerFC and tuning just for basic mods - is it worth it?
I dont know!!!
I dont know!!!
For the 2k you spend on the PFC and tune mate the car will run better and smoother, and thats with more power and being more fuel efficient too!! I'd say go for it, i plan to. :huh:
can you remap an r33 ecu?
i thought it was just r32s?
i'm not sure if anyone is australia does it. i have been told a place in brisbane does it. i have a remapped 33 ecu that was done in japan.
if you are only running at 7psi and occasionally 11psi then you could go the cheaper option of a safc2. it will make a noticable difference.
It won't really make it 'safer' because it's not really at much of a danger as it is. If anything, the benefit is in fuel economy and performance. It will make it have more power basiaclly all over the power range.
If you're going to do it though, i'd make sur ethat you do every mod you'd consider, so you don't waste money on a tune again later.
e.g. fmic, full exhaust, turbo if you want, camgears, etc.
Instead of an safc, take a look at the jaycar one. it is basically an safc in a cheap looking box at about 1/5 the price.
Chris, I know OF a guy that can remap r33 ecus. I have nothing to do with him, he just posts up on here occassionally. I'm actually saving up for a remap myself just to see how it goes. From memory, last time he posted, it was 350$.
the jaycar safc will be around $100. then the tune will be like $300. SAFC only allows adjustment of fuel, not ignition.
I reckon the remap for 350 is seriously a pretty good option. Fuel, ignition map changes. Removal of speed limit. you still retain all the good stock ecu stuff like cold start, consult etc.
Edited by 97r33gtst-typeM
thanks for the info mate!
Yeah I knowe the general rule of do all your mods - then get it tuned to suit. however I feel that this is all I want to do as now I want to get the suspension set up for some track/hillclimb work and eliminate that bodyroll! :P
cool - if you like could you pm me this guys name?
Wouldnt mind getting in contct with him!
cheers!!
Chris!
posted by toshi in an old post
in order to tune R33 on dyno, board is needed, which approximately costs $350-$400 only board.
Tuner makes ECU map on dyno themselves and this data is transfered onto PLCC chip then fitted onto the customers ECU
Other wise use R32 ECU ( need change all map.not only fuel and ignition).
R33 chip is selling at http://www.grid.co.jp/en/prod/prod93.htm.
This is a one time chip.
when remapping ignition timing DIY, make E F colum same as D colum ignition timing. ( also remove speed and boost limitter)
This means about same AFC.
And adjust base ignition timing by crank angle sensor about 2-3 degrees.
There is no need for a fuel map change.
Because when fitting dump pipe and hi flow cat , cat back, air pod , boost 0.8-0.9 bar A/F changes to about 11. (depends on parts performance)
A/F 11 is not rich. HKS kansai drag racer GTR A/F11 for safe and power.
I think rechip is cheaper way ecu tune for std turbo R33 GTS-T.(my map is totally different std map).
If change turbo in the future I recomend power fc for R33.
I think R32 do not need power fc.
If some one having pomping or fuel rich problem please send me PM or [email protected].
I be able to chack problem by softwear then I will fix it. ( NSW only)
http://users.tpg.com.au/yuna/Skylines.html
Basically a lot of mucking around and will be hard to find someone in your area to do it.
Edited by Munna1
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
