  • Replies 43
Most of the bad threads to do with Prestige and J-spec have all been deleted. Mainly because J-spec sponsors SAU (not sure if Prestige does). That said J-spec are reasonably good though. See your in Perth.. PM sent
mmmmm, generally people who have had bad experiences have no one to blame but themselves hey :woot::)
I love misinformation :) I have never deleted threads on SAU because of sponsorship/financial status.
Anything posted on SAU is the responsibility of the owner (Prank) who has created the SAU Guidelines and made it clear that he doesn't tolerate negative comments directed towards businesses.
what makes you say that?
Well with the importing process/purchasing of your new car, both with j-spec and prestige...they make it very clear that they are only in the business of aiding you in chosing the right car for yourself. Auction Grading, mechanical inspections and high resolution pictures are at your disposal to help you make this choice. What i am saying is, at the end of the day, YOU are the one that choses the car. Therefore if anything goes wrong mechanically or anything else thereafter it really isnt anyones fault but your own.
thanks.
Edited by Sambo33gtst
Why not buy a car thats already here? You get a chance to inspect it yourself, take it for a test run, and get a workshop to inspect it too.....
Because someone has to import it at some point in time, provided you do the homework like Sambo said, it's generally going to be okay. I still think it's competitive cost-wise to import over buying an already-imported car.
You took the words right out of my mouth :rolleyes:
Generally if you import yourself, and i did say generally, you can save anywhere between $1,000-$5,000 compared to if you bought privately here in Australia (Typically R33's). Just got to be patient and find the right one for the right price :)
  • 1 month later...
  • 4 weeks later...
J-spec dont really ask prices for anything mate. they offer a service to find and help you import cars from japan. they simply ask their fee ($1000 AUD from memory) to find the car (either at dealers or auctions) and buy it on your behalf and help you import and comply it. so what the car costs is up to you.
and in my sig :mellow:
I think we did have a couple of 180sx's for 15k landed n complied... mind you they were 1996 models which hadn't been drifted/thrashed to an inch of their life and hence ineligible to be imported under SEVS (the only way you can import a 180sx these days).
I'd easily recommend J-spec. Although I'd recommend that if you want to buy, have all your finace organised first. I'm sure they get the 'I'll call back once I've got the loan" all the time.
Yeah the sales guys do get that from time to time, but we've given quotes and in some instances spoken to the bank etc where they need something solid to approve the loan. Some banks are hesitant to give loans to purchase cars that aren't in the country for some reason :laugh:
and in my sig :laugh:
Why is it that a car that hasnt been drifted/thrashed ineligible to be imported under SEVS? Am I reading this wrong? I thought 180's are eligible under SEVS
No I meant that most non accident damaged 180sx (ie eligible for SEVS) haven't been drifted or thrashed. Depending on the compliancer and engineer involved, even something like a repaired rear fender could fail compliance.
lol i should have put a comma in there to break it up.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
