  • Replies 74
' date='14 Oct 2006, 12:17 AM' post='2581709']
still got:
R33 GTST Series 2 Dash surround including aircon vents (missing power arial switch) $150
(also need then ones that go in the door, and just behide the front winscreen for the aircon)
will u ship to perth?
+$25 in box and protected for shipping
How about the underhood snorkel? You know the little black thing that goes from under the hood into the airbox.
-Sayajin
no sorry
do you by any chance have the internal fuse cover or the engine bay relay cover?
no sorry
:w00t:
I'm after the little pocket that sits undernearth the head unit, have you got it separate or is it part of the centre console? and price?
Thanks
are you talking about a DIN pocket? These can be had from Nissan for about $15 - $20.
Got one in my car, because I upgraded to a Single slot (din) head unit.
do you have a the Front grille? Is it a series 2 if you do?
If so, sold to me.
Thanks
do you still have the series 2 front indicator and fog light assemblies? Would b interested.
This was a a front impact crash
There is nothing available that is not in this thread.
Hey i only need a left hand rear tail light if you still have it will u sell it individually. For my 94 r33gtst
phone: 0406075274
Pm sent :laugh:
Do you have the high pressure hicas power steering hose or the stock turbo to intercooler piping?
Yes i have all of that :P
Where are you located?
Your pm box is full mate.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
