ebay will have everything but the wing.
or autobarn for the LED lights and possibly the eye lids, and possibly the mirrors.
for the wing try some panel beaters.
Edited by mad082
Just recieved my R34 COUPE and wanting to fit AERO MIRRORS, REAR WING pics below EYELIDS and LED REAR LIGHTS.
Any information on where to get these would be great, businesses or Forum members.
Post up here or pm is fine.
I'm located in Brisbane.
Cheers
DMD? ur in queensland so try them for that stuff, maybe not the LED lights htough i dunno
The led tail-lights look damn cool but are a serious waste of money IMO. I think they're extremely expensive but maybe they were just the set i saw. Can't remember where i saw it.
BTW what set of wheels are in that pic??
The Nismo genuine tail lights are close to $1000 landed. The aftermarket copies are horrible and have not matched the pattern of the nismo lights and look poor as a result.
As for the eyelids, you can buy genuine ones from Nissan. The part number F2410-AA007 FIN-HEADLAMP SET (part number varies per color, that is for black).
As for aero mirrors, the only ones you want to get are Ganador's. Theyre a direct bolt on available in all standard Nissan colors as well as carbon fibre finish and retain all electrical functions. For those the best prices are Yahoo Auctions or Nengun - See www.slidewizeimports.com to help you buy it or www.nengun.com for Nenguns website.
Wow i didn't even know they had genuine ones. Got a picture of them? Also a price for them?
Edited by Howie
Very few people took that option.
Here is a pic of the factory eyelids on a R34:
http://www.sewid.org/gallery/d/2296-4/photo55.jpg
Price is - unknown
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
