Hey,
A mate of a mate of mine offered me a cheap port and pollish for my R34 GTT yesterday and was wondering if i should go ahead with it or not.
I have some understanding of what is involved but i just wanted to get more info before i do anything about it.
What are the pros and cons of doing it and has anyone else done it to there GTT?
Is there a noticeable power gain and saving on economy?
He said he will do it for $50 / cylinder = $300 plus the cost of getting the head re-done and it will take about 2 days... is that a decent price?
Would people recommend it, and if not, why?
Any comments are greatly appreciated!
Thanks.
https://www.sau.com.au/forums/topic/130142-port-and-pollish-on-r34-gtt/
What do you mean the "head re-done" and how much for that? Last time I checked that part of it would cost $500-600 making the total $900ish which is still cheapish but do you need it? We need more info on your setup to answer that question.
yeh its worth it...if your engine is already pulled out and apart and your doing other mods to it. But just for the sake of pulling your std motor apart and getting the head port n polished and then faced with a maybe on the valves if thats what hes referring to for the 'head redone' then its prob not worth the hassle for the money even if it is cheap.
Hey,
Thanks for the replies guys!
Yeah, i am using the stock turbo right now with no plans to upgrade it till it dies...
I still have stock ECU, injectors, fuel pump etc...
My current performance mods are:
- Air pod
- Exhaust
- 600mm FMIC using stock piping
I think he meant getting the head machined or something, and he mentioned something about the lifters too...
The car only has 56,000kms and hasnt been flogged from what i can tell, so the engine still should be in very decent condition... He recommends getting it done as it is a decent price and gives you more power etc... but if its gonna cost another $500 - $600 for the head, i think i'll leave it.
Next time i see him ill ask what exactly needs to be done to it, coz he said he has to get that done by someone else as he doesnt have the equipment to do it... i thought he said its around $150 though? I'll have to double check.
Thanks all.
I'm probably way off the mark here.. but isn't the idea of machining your head to increase compression? Don't you want to decrease it?
Tell me if i'm wrong guys.
Depends which part of the head you machine.
Another couple of costs you seem to have forgotten about are a new head gasket and labour.
Also with stock everything there is absolutely no point whatsoever in doing this mod.
DON'T DO IT.
I say otherwise; DO IT :P
Change the head gasket; change the valve springs; camshafts; valves... replace head studs; do the port and polish and end up with a race-prepped head!
Sure you might live in a cardboard box after; but you know it ain't stock no more!!!
Ignore this person. He is an ass.
waste of time for your set-up. $1000 could be spend elsewhere for much better gains.
Agreed
Far better bang for buck mods witrh your setup.
I could think of around 8 grand you can spend elsewhere before even coming close to needing porting
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
