Wtb: 17" Gtr Offset Rims For Track/drift Use.
Hi all, i'm looking fer a spare set of 17" rims fer track and drift use. Preferrably at least 17x8. The cheaper the better but price im willing to pay depends on rims itself. GTR32 offset needed.
PM me if u have any fer sale.
Cheers~
Edited by J-Boy
Thanx Deni...but i really dont need the road radials...would love to just buy the GTR33 wheels but without tyres cuz im only gonna use semislicks with it...
Hi there, I have a couple of possibilities that you or someone else might be interested in. Firstly, set of Enkei lightweight 2 piece wheels 17 x 8 and 17 x 9 and +35 offset I think. 275/40/17 tyres on rear - small amount of tread. 245/45/17 Yokahama 048R semi-slick tyres on front with only a little life left in them. $750 set.
Also a set of lightweight Volk Racing 2 piece wheels of the same basic dimensions. These wheels use the PCD adaptors for bolt pattern and offset. No tyres. The two 17 x 8 rims have a couple of small cracks in inner rims to repair and are fairly well used. $300 set.
Can anyone interested please call me on 0416076187 as I do not always check my computor. I am in Sydney.
dat120y: thanx...but the offset i need would be somewhere around +22 and im looking fer a width of ard 9J on all 4 wheels...good luck with the sale~~~
Cheers~
I've got a set of wheels similar look to the first ones posted by 'dreamaut0works'.
All four (rims only)
17x9 +20 offset all round.
PM if interested.
I've got a set of 17x9 with an offset of +22 would be perfect for your usage. They are the advan three spokes
The tyres i have on them are the falken semi slick style thread, but different compound... think they are 235/40/R17s with about 50% thread on them.
1k the set
Send me a pm if you are interested.
Cheers
Liz
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
