I understand the disadvantages in having injectors that are too small.
But so far the only negative towards bigger injectors is cost. and as stated previously the difference between 550cc and 740cc injectors is only around 50 bucks.
Which brings me to the question. Can i have injectors that are too big? advantages/disadvantages.
Cheers guys.
Fuel economy decreases generally speaking the larger you go.
Being it is hard to get larger injectors to behave like smaller ones on idle etc.
i've moved back to 550's with my RB26... so we'll see if there is a larger difference.
That said, with 740's i still managed around 350km to a tank :(
For me, that was pretty good
For a mild street tune has anyone tried upgrading stock R33 injectors with a JDM spec S15 injectors rated at 480cc/min? Will those injectors fit straight away without any mods?
The problem is most package are sold in set of 4, so either you buy 1 set and then hunt the remaining 2 or buy 2 sets and try to sell the spare 2.
Cheers guys.
Let me start of by stating that I am not the world’s best tuner, far from it. With that out of the way, I always find it harder (more time consuming) to tune a car with larger than necessary injectors. That means slightly higher tuning costs, if I was doing it (not that you would want that) .
Secondly, all injectors are not the same flow rate, commonly you will find 1.5% to 3% variation in their individual flow rates. I find larger injectors are at the higher end of the scale. So 3% of 740 cc’s is a lot more than 1.5% of 550 cc’s. You have to tune for this larger variation between cylinders. That’s a little more time on dyno.
All together, the above may not amount to much extra $cost. But it is worth keeping in mind.
:) cheers :O
PS; I have seen a standard Power FC handle 1100 cc injectors easily. After you shoot the guy that told you otherwise, hang him just to make sure he can’t spread that crap any more..
Yep they work just fine, last time I did it I bought 3 sets (of 4) and did 2 cars.
Keep in mind that it is only the JDM S15 manuals that have the 480 cc injectors. Not all S15’s.
:) Cheers :O
:) Cheers :O
Is there a way to quickly differentiate these 480cc injectors from the non-JDM local ones? e.g. colours?
With that quick calculation does it mean that a std 370cc RB25 injectors will support up to 370BHP or 276kw at flywheel or about 211rwkw?
I've got my stock AFM maxing out a bit early at 206rwkw, and without upgrading any injectors except a Z32 AFM, I'd probably only get another 5kw or so for my $400?
Yeh those figures add up right. However, if you wanted to cheat as SK has said before you can raise the fuel pressure and squeeze more out of them after you change the afm, most ive heard out of std injectors is about 230rwkw...but i would say give or take 10rwkws for dyno differences. As some people have said more (upto 240rwkw) and some have said a little less (220 odd).
Thanks... I think the FPR one is a cheaper way to get more power. I'll see how it goes after it's tuned tomorrow.
If not, then forking out a little bit extra on the S15 ones seems like the best path for my small HKS2535, as with its power rating of I feel getting a Nismo 555cc injectors are way overkill.
Those are aftermarkets, they have of course different colour coding than the OEM factory ones. For Nismo brand, 555cc is yellow, 600cc is purple, and 740cc is red.
Ok good, I havent been able to find any Nismo colour meaning, thanks
Hi people. What about some other brand apart from Nismo, Sard etc. Was wondering if
Bosch do a replacement injector. Does anyone know if Bosch do and if so are they heaps
cheaper, about the same, good or shite.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
