*shugs* could be the magnetic lines of the earth?
You coming along Chris? There are some great spots to spin out at high speeds in NSW like turn 11 at Wakefield and turn 6/7 at Eastern Creek :)
Yeah i'm working on it. Problem is Dutton sent me broke, and I don't think I will get another track day out of the de-laminated pile of rubber I have left.
  • Replies 418
Posted Images
pfft soft wang
turn 9, turn 11 its all just numbers when yuo can't count :(
Liz.....Kel is the champion of taking someone up the inside under brakes in the first turn....did it on her first race much to the other bloke's surprise :(
Listen to all the excuses come out as the date looms closer. My GTR blew up. My GTR doesnt have tyres.
I cant afford new tyres either, wont stop me from using my road tyres and sliding around everywhere having a ball and making plenty of noise ;)
No tyres...weak. Go and get a used set of road rubber and slap them on for $150 all round
I cant afford new tyres either, wont stop me from using my road tyres and sliding around everywhere having a ball and making plenty of noise :P
If you buy the tyres... I'll put on the 4WD drift extravagansa. That's how broke I am right now. I had to eat baken beans the last two nights.
The rest of the office loves that new fruity aroma surounding my desk thou!
LOL...im not kidding either. Im getting lifts to Geelong because i cant afford fuel for the car, i mean i cant afford fuel as i dont have a dollar to my name. Im living off tin soup for dinner, an egg on toast for b'fast and a carrot, some lettuce and a tin of tuna for lunch....and so it has been since the Dutton weekend. LOL cant wait to get paid this weekend :)
The i have to try and get the bar sorted and the car ready for Calder...no money, no time...failing a course i paid good money to do...lol feckin cars :D
Bah HumBug to that Chris. You have a set of Michelin Pilot Sport Cups on 17's you can bring along so IF the set of 18's semi's do go bang you can have a back up set to play on / get home on. Tyres excuse is not on for you dude! Those Pilots are a lot better now they have been scrubbed in than they were on that 1st test you did with them. And the fronts from Dutton and the other rears are still ok too.
Looks like I'll be coming up on a test set of Toyo's so I don't think I'll be breaking any track records - but I know even on the Toyo's I'll still be faster than any of these NSW gimps. You would be too on old RE55's or the Michelins. :)
Pilot Cups are slow... Plus they are on Ferni's car ATM, because I have to re-spray his rims because we failed to look after them for him.
snowoman, getting pounded by us at a NSW track is weak. i'm thinking i might head up to PI or sandown next year and dish out a bit of whoop ass.
There's already a trip being planned.
It better be to Phillip Island. The only other reason to come to Melbourne is for DECA which is kewl.
dont you worry snowoman. PI is the top of my list outside of NSW. i'm over wakefield. EC is good. OP GP is good, but short circuit bites the pork sword.
:yes:
i may be slow but i can talk the talk, and i have a hard corey seat and harness which makes me look like i mean business.
Ive heard great things about DECA
Be careful carrying it accross the border. Its pretty good as its pretty anabolic but not too androgenic...still be careful though ;)
AND, i forgot about those farkign tyres...get your ass to Sydney. You have no excuses, you are driving around on our farking race rubber...what a fark up that was ;)
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
