Everyone to their own, but I can't stand the series II front bar... looks hideous - otherwise, very clean car... should get it tinted though.
Cheers.
At least it isnt as bad as the series one front bar..
The series 2 needs the nismo lip to make it look nicer
like this :(
like this :D
haha I've had that lip sitting in my house since July, just needs to be fitted and painted... Lazy bastard. Have always loved the look of lip extension and gtr wing. Stock appearance but just adds a little more.
Update: Engine build is almost complete :banana:
Still alot of fabrication required, but should be ready in 2 weeks!!
For those that haven't seen my car or can't remember it, some old pics. These will be updated in a couple of months.
post-1811-1203670146_thumb.jpg post-1811-1203670225_thumb.jpg post-1811-1203670045_thumb.jpg
Update: Engine build is almost complete :thumbsup:
Your s1 looks great. ;) engine bay is awesome. gt30?
MotoMan - is ur front lip geniune nissan or is it aftermarket? coz i find aftermarket lips dont really fit well like the geniune ones, correct me if im wrong :)
Edited by Charles89
Im pretty sure mines genuine nissan..
aftermarket are generally fibreglass, and mine isnt fibreglass
just a few photos of my r33 when a few of us went down to benaraby for the friday night test and tune, had a crap night let just say i wish i hadnt had gone, alot went wrong, but it wasnt with my car so everything is well :D
hope u like the pics.
thanks to blake who took the photos for me.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
