i got it from carmate.
they dont come cheap though, lol
Hey mate, can you please tell me if these hods fit good?
Also, can you please send me a link from carmate's website to the same one you got?
Thanks.
Thanks.
I'll be buying one from PSI parts soon... Definitely need a vented bonnet, things are getting very warm.
Well car is now back on the road - in it's run-in tune
Here are some updates of the engine bay and run-in tune.
Engine bay looks tidy. Great power figures for a run in tune. Let us know what it makes when its run in.
just got my coilovers installed by Anth & Alex @ Dahtone Racing :P
BEFORE:
AFTER:
( sorry bout the dodgy camera phone pix :P )
exhaust sits 3.5cm off the ground (1/3 of a V can - in this case its a PimpJuice can :lol: ). I will raise the rear end when i take the car out again lol
but that aside..... it looks hot :)
edit**
just came back from a nice drive, coilovers feel awesome!
going to raise the rear end tomorrow though :(
heres some last pics before it gets raised :)
so happy with them :D got a smile from ear to ear :D
Edited by McDrifto
McDrifto - love it!
seriously i'd just leave it like that and not ruin it with any bullshit kits or rims
:D
sif leave the stockies on for looks. get some deepdish 16' or 17' if u wanna leave the car at that height. agree bout the kit tho
fark man your rear camber tyre were that low will be awesome... :thumbsup:
heres my nugget yesterday.
got my standard 33 rims back on as they have my semi's (r32 gtst rims painted black for normal driving)
ive decided to save up for some new rims so it sits higher and also i want a CF hood - no crazy body kits here :)
i adjusted the coilovers to the highest possible safe point (left 2cm of tread in the purches/cups) and measured all 4 so they were even lol
the coils themselves are all the way up and cant go any higher... that means it wasnt on the lowest setting yesterday LOL
heres a pic of the car at its highest setting
what coilovers are they? are they bottoming out at that height?
HSD coilovers with soft spring rate. They dont bottom out and it wasnt on the lowest setting in the previous pics, the ride is smooth!!!
In the previous pics the bottom purches/cups were wound all the way down, the coils themselves were all the way up. The coilovers could of been wound down a lot, which if it was you wouldnt be worrying about bottoming out because your car would be dragging on the floor
Edited by McDrifto
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
