We have way too many sports cars at the moment... those two skylines, which were moved to fit the new supra next to the old supra, and I'm looking at another soon...
And I have to move in like 4 weeks! :/
Nice 33 Simon,
By the way...completely off topic, but do you still get good air flow to your cooler without the front bar cut out like i've seen on others?
cheers m8
i dont really see any adverse effects from not cutting the bar, and i would rather leave the bar as is, just think it looks better?
i would ideally like to fit a longer narrower cooler to improve things, but i have yet to attack that idea, summer job, and see what i can fit?
also thinking about water spray on cooler and maybe nitrous spray bar?
i have a complete with extra bits kit from the wizards of nos, which i took off my 220 turbo, with two 11lb shiny polished bottles :)
where the hell to put em is the next issue lol
cheers m8
Something like this.
I was thinking about buying this and just buy a piping kit.
Are you running standard turbo? Any power increase/lag?
that looks like what i was considering......., no running a hks gt2535 (i think thats the number) bit laggier than std, but 1 bar at 3k rpm, allegedly running 350 bhp? i think its less tho, gotta get it rollered at some point to see :)
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
