Nice work, are they the endurance caliper? Do they take a 36mm thick rotor and 30 mm thick pads?
Do you still run ABS? I can get mine to lock up for a tenth of a second before ABS kicks in and does its thing. Thats running RE55s tyres...
Like the pic in your sig, looks familiar....
Sweet pic dude. Yeh they are the endurance caliper with 36mm rotor and 30mm pads.
As you can imagine, they never fade. Ever.
No ABS on mine, have never used it. Find it kicks in prematurely in the GT-R's and you can brake better if you get your braking zones perfect.
On the other hand, it makes it harder, so I'm probably looking to go to something a bit less serious and a bit more street friendly.
F*CK YEAH. that is mint haha.
my 31 daily looked like that a few weekends ago :)
haha cheers :)
LOL WTF?!
if you aint layin rail you fail
LOL thats chapel st spec..
bro!
please
You need a chapel pass before it is true chapel spec lol
i used to live in werribee and im not ethnic.
needs more low :D
GTFO :D
I find the ABS to be idiot proof, just go in late and stand on the pedal has hard as you can!!!!
Without ABS it would be much trickier.
What brakes you running on the rear??
Just stockers. After driving mates GT-R's with upgraded rear brakes I definitely prefer a front bias. They all seem quite twitchy in the rear and I just can't justify the extra cash haha
that bumper looks like a pretty good fit aye
Where did you get it?
thanks mate! actually there is a slight bulge just below the grill which i havent got time to fix..! i got the front bar from japanautos wreckers located in redcliffe, brisbane.
S1: nice and clean and smooth, match's the lines of the car with nothing out of place.
S2: oops we forgot the indicators, does not matter just jam them in some where and use some sqaured off corners that dont match any of the lines of the car, people will love it coz its a S2.
The S2 indicators/fog lamps follow the 00<<>>00 style of the tail-lights...it balances the car, plus also to me it's bold, uncompromising, distinctive. The same S1 lights just look generic like off a camry or something.
I'd like to see someone use angel eyes in those fog lights.
S2 FTW! :)
Edited by Tony de Wonderful
No it's been proved to be more effective than any professional driver in perfect conditions.
It's one driver aid you can't argue against.
The only thing maybe is it encourages complacency.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
