Hahaa, yeah you say that now....... :)
I dont see the point in buying a performance car and then making it "NOT" perform....
Go put chromies on a lexus or something and stop giving performance cars a bad name.........
Edited by Arthur T3
It is factory plastic, but has previously been cracked and repaired only with bog / spray so cracked easy again.. now myself and father just repairing it properly with the correct method hopefully holds better then previously.
be prepared to destroy your front lip if you go too low
only if you dont know how to drive
so lowering a car makes it not perform? :ermm:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
