Got some fitment issues up the front. 20 * 8.5 +25 rims.
The wheel is physically too large in rolling diameter and is rubbing on the top suspension arm. So I need to hit the drawing board.
Anyway the test fit...
What are you guys thinking? Improvement or not? I am going to slam the car back to the ground with the new rims, remove the wing, and try and line up a carbon fibre duck wing and roof spoiler.
I think the new rims need a new look...
yea they look hotttt,
slam to the ground, get the duck lip if you want, but i dont know about the roof spoiler i dont really like the look of them
but definently make these rims fit and slam the car to the ground :D
what size tyre on the front?
i like it but i dont know how you'll get around the front lip been a mile from the road purely because of the size of the rim you wont be able to reduce it much.
still nice wheels an all.
ROOF SPOILERS ARE FKN AWESOME.
Yeh im worried this suspension arm might be the death of me!
I took some pics to show it. Hopefully with a 5mm spacer on the front and a stretch say, 215/30/20 on the front. But turning still might pose problems, and I think full lock is out of the question lol.
But I mean come on bulk people have fitted 20s before to 33's (all be it chromies :(), surely there is an easy solution. Aftermarket suspension arm (thats less bulky)?
Oh and the tire on the front atm is a 245/35/20 I think. I wont go that wide on the front with the new tire, which will save me some space... but the new tire will have tread aswell (where thisone is down to the wire), so i fear it will even itself out abit there!
The Cannon Exhaust is about to go though. Looking to cut the tip off and weld something a bit quieter on the end to try and get a crisper less droney note
cool lower lip on the bar man, wheres that from?? accentuates the front even more than normal...which im starting to love :)
Just Jap. Took a lil bit of trimming and adding to fit. Otherwise it aint too bad. Just replaces the factory lip. Gives it more of a sporty look to the front without looking over the top whilst keeping the strength and fit of the factory frontbar.
Luke
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
